A/C compressor removal
Old Aug 13, 2004 | 08:24 PM
mikeyg's Avatar
Default A/C compressor removal
I have a 91 honda civic. What will I have to take off in order to get the compressor off? Should I go from the top or bottom?
Old Aug 13, 2004 | 08:25 PM
crxgator's Avatar
Default Re: A/C compressor removal (mikeyg)
both, get the top two bolts from the top and the bottom two bolts from the bottom, this is of course you already loosened and removed the a/c belt...
Old Aug 13, 2004 | 08:26 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
you'll have to go from the top
and if you got freon get it evacuated and if you got no froen just take off the two bolts on the top to get the high and low pressure valves off, then there are 3 screws connecting the bracket
thats it
Old Aug 13, 2004 | 08:30 PM
mikeyg's Avatar
Default Re: A/C compressor removal (crxgator)
I cannot get to the bottom bolts from the bottom, its got a bracket that goes across that blocks access. And its a very tight fit to be able to get down there from the top. Any suggestions?
Old Aug 13, 2004 | 08:42 PM
MugenHonda's Avatar
you need a small wrench
Stunna MIKE
Dec 23, 2008 05:23 PM
BoRiCuA
Aug 3, 2007 03:21 PM
KayOs
May 31, 2004 12:46 AM
etp72
Aug 22, 2003 09:23 AM
89 CRX SI
Apr 10, 2003 08:22 PM
