installing header and exhaust
Old Aug 13, 2004 | 04:41 PM
972drcordex's Avatar
Default installing header and exhaust
trying to install my header and exhaust on my 97 accord. Can anyone give me a quick link or instructions on how to step by step do it, so i dont **** up.
Old Aug 14, 2004 | 01:56 PM
yeegsr's Avatar
Default Re: installing header and exhaust (972drcordex)
you dont need one..they pretty common
just jack up the car...look for bolts and remove in the order...
when you jack up the car...and go under it...it looks pretty simple..trust me thought it was hard too...but after that things going well...
have faith...or you can go here
http://www.g2ic.com/tegtips/
Old Aug 14, 2004 | 02:39 PM
JDM.Accord's Avatar
Its some of the simplest work you will ever do as far as bolt-ons go. Just look for bolts around the head and exhaust and take them out.
Old Aug 14, 2004 | 07:29 PM
fw190bvi's Avatar
Default Re: installing header and exhaust (JDMAccord2nr)
becarefull not to bust off the bolts holding on teh exhaust manifolt......those will have gotten to know the head very well, and will be very sorry to leave it, if ya know what i mean........use a penetrating lubricant on all the flange bolts.......while you at it, you might as well get some new rubber exhaust hangers......by now, your old ones are probably misshaped by fatigue or begining to crack
Old Aug 15, 2004 | 07:22 PM
accordracer789's Avatar
very simple i just installed some dc sports on my 98 accord and it just self explanitory just dont end up wiht extra parts
Old Aug 15, 2004 | 07:38 PM
madd's Avatar
Default Re: installing header and exhaust (accordracer789)
like a few people said, the biggest problem (especially with the header) is you dont want to over torque those bolts. you'll snap them off in a heart beat. good luck man
Old Aug 15, 2004 | 10:15 PM
Riceburner247's Avatar
Default Re: installing header and exhaust (madd)
Pretty straight forward. Just unbolt old, bolt on new.
Old Aug 16, 2004 | 06:54 AM
phoenixitc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordracer789 &raquo;</TD></TR><TR><TD CLASS="quote">very simple i just installed some dc sports on my 98 accord and it just self explanitory just dont end up wiht extra parts
What if you are short parts?
Old Aug 16, 2004 | 07:44 AM
iakona's Avatar
you have bigger problems then. make a trip to local honda parts counter.
Old Aug 16, 2004 | 02:17 PM
NacTEXAStuner's Avatar
<U>How to remove and install a factory header and replace it with a one-piece after-market header:</U>
(1) Place the front of the Vehicle on Jack stands.
(2) With a 10mm socket, remove the A/C Line support bracket (circled in blue)
(3) Using a 12mm socket or wrench, remove the 4 bolts that attach the Exhaust Manifold Heat shield.
(4) From underneath the vehicle using a 14mm socket and long extension, remove the 3 nuts that attach the down pipe to the exhaust manifold.
(5) With a 14mm socket, remove the bolt that holds the manifold support bracket to the block.
(6) Remove the 2 lower nuts that attach the support bracket to the pipe with a 12mm socket.
(7) Loosen the two upper bolts that attach the bracket to the block.
(8) Using a 12mm wrench and a 14mm wrench, remove the two bolts with springs that attach the pipe to the Catalytic Converter and remove it from the vehicle.
(9) Using a 12mm socket with an extension, remove the seven bolts and 2 nuts that attach the stock manifold to the head and remove it from the vehicle.
(10) Using a 22mm wrench, remove the Oxygen Sensor from the stock pipe and place it into the header.
(11) This one piece header requires installation from underneath the vehicle.
(12) Remove the front splash shield.
(13) Install the header from underneath. You may have difficulty getting it in, but be patient. It fits this way.
(14) Now the installation is the reverse of the removal. Once done, double check your installation and for leaks or rattles.
The best I can do for you man. Good luck.
scubba
Honda S2000
22
Oct 26, 2007 11:17 AM
jdmpremonition
Feb 26, 2006 02:06 AM
staticrex
Feb 19, 2006 06:29 AM
