Exhaust installation
Old Aug 13, 2004 | 03:56 PM
PreludeFan7's Avatar
Default Exhaust installation
What tools do I need to install my Greddy Evo 2 Exhaust to my 00 sh prelude?
I wanted to do it myself, I heard it was pretty easy to do. What steps
do i take, what do i need, etc.....? Or do you think i should have a pro do it?
Old Aug 13, 2004 | 04:08 PM
LowFlyin''s Avatar
It is a fairly straight forward installation. If you have access to a lift...do it there.
WD-40 (to lube the hangers), regular screw driver (to pry off or attach the hangers), maybe some new hangers (just in case), and a 14mm or 17mm socket, 9 inch extension, and swivel. Air and an impact gun would be nice to break loose the bolts on the old exhaust. Some penetrating lube/oil would be good to soak the old bolts with before you try to break them loose.
If you can get under the car...you'll see how the exhaust should be hung.
Old Aug 13, 2004 | 04:11 PM
Kal's Avatar
Kal
Default Re: Exhaust installation (PreludeFan7)
Get new gaskets from your local honda dealership while you're under there. (exhaust ones)
Old Aug 15, 2004 | 04:51 PM
LowFlyin''s Avatar
My exhaust came with new gaskets.
Are you talking about the ones forward of the cat?
Old Aug 15, 2004 | 07:34 PM
Bryan-95prelude's Avatar
Also you might want to get a hacksaw or something and a power drill with alotta bits because if the stock exhausts bolts are welded on your gonna have to cut them off and drill them out
bryan
xnvb
15
Jan 23, 2009 05:47 AM
scubba
Honda S2000
22
Oct 26, 2007 11:17 AM
Acidcrakker
Sep 18, 2007 08:15 PM
5lugSlug
Mar 18, 2006 03:20 PM
