can you add v-tec to a non t-tec head?
Old Aug 13, 2004 | 03:48 PM
lillthingz's Avatar
Default can you add v-tec to a non t-tec head?
I have a D16A6 it is a 1.6l non v-tec is there any way that i can make it a d16z6 or add v-tec?
Old Aug 13, 2004 | 03:50 PM
TheNasty0ne's Avatar
Default Re: can you add v-tec to a non t-tec head? (lillthingz)
Search "miniMe swap"
Old Aug 13, 2004 | 04:02 PM
beaterdriver's Avatar
get a vtec head
Old Aug 13, 2004 | 04:08 PM
Deemeetree's Avatar
Electrician
Should be able to swap in a D16Z6/D16Y8 cylinder head, but also need to cosider the electronics.
The D16A6 is from the pre-1992 right? If it is, is it OBD-0? If so, the Z6 head is OBD-1 and the Y8 head if OBD-2. Definitely need to consider that also.
But, I believe you can get good compression ratios with A6 pistons and a VTEC head such as the D16Z6. Most people swap in the A6 pistons with a Y8 cylinder head and a thinner head gasket to yield GOOD compression numbers.
Do some more Search on here, lots of information.
Old Aug 13, 2004 | 04:15 PM
91civicDXdude's Avatar
Default Re: (Dimi)
[QUOTE=Dimi]Should be able to swap in a D16Z6/D16Y8 cylinder head, but also need to cosider the electronics.
[QUOTE]
Actually, the cylinder heads have nothing to do with OBD-anything.
its the intake manifold electronics and the distributor & ECU. Use d16a6 components and you're set, or convert your harness to OBD1 and use P28 ECU
Old Aug 13, 2004 | 04:19 PM
Deemeetree's Avatar
Electrician
That's what I was saying. The cylinder head electonics. Such as VTEC solenoid, distributor and intake manifold. Those are part of the cylinder head.
Old Aug 13, 2004 | 11:23 PM
lillthingz's Avatar
Would the head match up easily on th d16z6 block? or would I have to modify stuff on the d16a6 head for it to work?
Old Aug 13, 2004 | 11:41 PM
careawholelot's Avatar
Default Re: (lillthingz)
vtec is da bomb ish whhhhhhhhhhhhoooooooooooaaaaaaaaaaaaaaaaaaaaaaaaaa
Old Aug 13, 2004 | 11:58 PM
CD7power's Avatar
man...that sounds like a lot of work. save $ for a swap.
my 2cents
Old Aug 14, 2004 | 03:26 AM
civtegra_hybrid's Avatar
fact, you can't use a non vtec head and turn the non vtec head into a vtec head!!! and even if there was any way it hell you could it would cost more then what's it's worth, the best bet is to buy a D16y8 head off a 99or 00ex, (higher comp.) and slap it on, run a vtec, diss. and get a p28 ecu and wire the vtec wires, and call it a day. O yeah and mill in 30xxx's for that extra kick
Old Aug 14, 2004 | 04:00 AM
menkio's Avatar
Default Re: can you add v-tec to a non t-tec head? (civtegra_hybrid)
haha.. add vtec.. thats cute
Old Aug 14, 2004 | 06:53 AM
Jon V's Avatar
Default Re: can you add v-tec to a non t-tec head? (DewMota)
where is that piture with the V-tech phone on top of the valve cover?
I guess I need to take a new one
Modified by Jon V at 4:07 PM 8/14/2004
Old Aug 14, 2004 | 06:57 AM
H22A EG6's Avatar
Default Re: can you add v-tec to a non t-tec head? (Jon V)
well when i needed vtec i bought a bottle of vtec juice and just added it to my oil
Old Aug 14, 2004 | 07:12 AM
senpai's Avatar
Click the link in my signature, everything you need to know
Old Aug 14, 2004 | 10:35 AM
CHONCH's Avatar
needs more elvis.....
Old Aug 14, 2004 | 11:13 AM
theSQad's Avatar
Default Re: (Mugen562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen562 &raquo;</TD></TR><TR><TD CLASS="quote">man...that sounds like a lot of work. save $ for a swap.
my 2cents</TD></TR></TABLE>
stfu its not alot of work
you just dont know what your talking about
Old Aug 14, 2004 | 03:17 PM
lillthingz's Avatar
I don't see how it would be hard to put a d16a6 non v-tec head on a d16z6 block. I have a d16z6 motor i just got the a6 headand it was ported so i said hell why not try putting it on, maybe i ill get some gains? i duno that's why i asked yall about it, hoping i would get some insight from people with more motor knowledge.
Old Aug 14, 2004 | 04:58 PM
FlipSkater
Guest
Posts: n/a
Default Re: (beaterdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterdriver &raquo;</TD></TR><TR><TD CLASS="quote">get a vtec head</TD></TR></TABLE>
problem solved
ClutchPapi
Jun 4, 2013 07:13 AM
JohnnyEF
Dec 19, 2011 09:48 PM
AJxr
Sep 26, 2005 12:09 PM
poetter
Oct 23, 2004 11:43 AM
EK4civichatch
Mar 7, 2004 07:17 PM
