Current problem/radiator fan won't kick on
Old Aug 13, 2004 | 11:29 AM
89HFlikeamutha's Avatar
Default Current problem/radiator fan won't kick on
Alright here's the deal my friend just got an LSvtec installed which I think kinda has nothing to do with this, but for the past few days he has been having problems with his radiator fan kickin on....fuses look ok and everything else seems fine....what can be causing this problem....
any theories would be helpful
thanks
Old Aug 13, 2004 | 11:47 AM
jmcclell's Avatar
Default Re: Current problem/radiator fan won't kick on (89HFlikeamutha)
There is a coolant temperature switch located on the thermostat housing that switches the fan on when the coolant gets to a specific temp.
Locate the switch (Green plug), disconnect it and join the two terminals on the plug/loom side. This should bring the fan on. If it does, then the switch is faulty.
Hope this helps.
Old Aug 13, 2004 | 01:12 PM
Default Re: Current problem/radiator fan won't kick on (jmcclell)
Thanks I appreciate the info I will check it out see what happens
Old Aug 13, 2004 | 01:18 PM
egchan's Avatar
i have done a couple of swaps into efs and i never get the fan to come on on its own. i always use low temp thermostats and integra radiators for the dual core. but i know that the fans always worked before so i never seemed to find the problem. i wired the fan to switch in the unlikely event anyway. just my 2 cents.
therhett17
Aug 13, 2015 09:07 AM
nothing_shocking
Mar 10, 2012 11:57 AM
American.Graffiti
10
May 29, 2007 05:06 PM
