grinding gears
Old Aug 13, 2004 | 11:26 AM
LorenGeist's Avatar
Default grinding gears
the problem is that when im shifting fast into sencond and third it produces a grinding noise. It does not slip nor does it do it when i shift slower. is this the syncros? or what.
Old Aug 13, 2004 | 11:28 AM
B2FiNiTY's Avatar
Default Re: grinding gears (LorenGeist)
Sounds like the syncros. Change the tranny fluid and see what happens. `
Old Aug 13, 2004 | 11:40 AM
EP3_05's Avatar
Default Re: grinding gears (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like the syncros. Change the tranny fluid and see what happens. `</TD></TR></TABLE>
I agree, change the fluid and see if it helps. Otherwise it needs a rebuild.
Old Aug 13, 2004 | 11:43 AM
Eg_Ryan's Avatar
Default Re: grinding gears (91civic)
My tranny had a nasty grind in 3rd gear and i was told to buy Gm(General Motors) syncromesh tranny fluid. I drained my whole tranny and put that stuff in, about 2 days later my tranny was smooth as possible even at higer rpms. th stuffs about 11-15 bucks a bottle. It worked great though.
Ryan
Old Aug 13, 2004 | 11:46 AM
kid-honda's Avatar
Default Re: grinding gears (88_LsCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88_LsCrx &raquo;</TD></TR><TR><TD CLASS="quote">My tranny had a nasty grind in 3rd gear and i was told to buy Gm(General Motors) syncromesh tranny fluid. I drained my whole tranny and put that stuff in, about 2 days later my tranny was smooth as possible even at higer rpms. th stuffs about 11-15 bucks a bottle. It worked great though.
Ryan</TD></TR></TABLE>
I was just about to recomend that stuff, always try that first before you rebuild cause you might get some more life out of it.
Old Aug 14, 2004 | 12:43 AM
LorenGeist's Avatar
Default Re: grinding gears (kid-honda)
bump
Old Aug 14, 2004 | 12:05 PM
C-RICKS's Avatar
Oh yeah!!!
Well, i had a pretty bad case of grind-alot-tis and tried a few different products, including 90-95-95-100 gear oil. Let me tell you something, draining and refilling the tranny 8 times(thats 16 procedures) in under two weeks is a real pain in the ***.
I finally broke and tried this Lukas crap some people told me about. Boy let me tell you. Lukas is no crap. I have to admit that it was the most felt upgrade i've done to my car.
I'm in the Eyecare biz so, it's not like i work for them or anything. I just strongly recommend Lukas tranny/gear additive.
PS. I've also like to make note that the results from their motor-oil-additive were not as succesfull.
But i'm inlove with their tranny ****!
ef 4dr
13
Jan 13, 2008 08:54 AM
b16a27
Mar 26, 2005 10:08 AM
JSPECCRX
Mar 7, 2005 06:33 AM
Bigwool
Dec 17, 2004 07:56 PM
WONG FRIED RICE
Nov 20, 2003 07:41 PM
