fuse blew on amp...
Old Aug 13, 2004 | 09:58 AM
ilikemyaccord's Avatar
Default fuse blew on amp...
i checked my amp and noticed the fuses blew..so i bought replacements and when i touched it against the socket for the fuse, it blew. what does it mean? take out power then fuse it, then power it back up?
Old Aug 13, 2004 | 11:16 AM
ipleadthe5th's Avatar
Photoshop Guru
Default Re: fuse blew on amp... (ilikemyaccord)
Could be 2 small of a fuse. What size is the amp (watts/channels)? What is it pushing and how are the speakers hooked up (series/bridged)?
Is the amp getting pwr? Have you checked the fuse under the hood on the pwr wire of the amp near the battery? And what size is that fuse?
Is it doing that with the car turned on, cranked up, and/or off?
Old Aug 13, 2004 | 11:44 AM
Default Re: fuse blew on amp... (ipleadthe5th)
600.1 jbl amp powering 15" kicker l5...its worked fine for months...i use a 30 amp fuse for the jbl. my subs just turned off oneday and i just saw the ground wire unattached and thought nothing more..hooked it up and saw the fuses were blown .
Old Aug 13, 2004 | 01:08 PM
Eric R's Avatar
That amp could be damaged by now due to that past ground problem...
Old Aug 13, 2004 | 04:36 PM
skrewdriver88's Avatar
Default Re: fuse blew on amp... (Eric's R)
Disconnect the negative from the battery box.
Spazbaboon
Audio / Security / Video
Feb 26, 2007 03:36 PM
92ehatch
13
Nov 30, 2005 08:07 AM
walkerrod
Jun 2, 2004 08:57 AM
pr0jektdc2
Feb 9, 2003 01:19 PM
GoodFella
Jul 18, 2001 05:18 AM
