Custom motor mount pics?
Here is a page covering the ones I built;
http://www.performanceforum.co....html
I've got to say that unless there is a real driving reason for making your own, you are best off just buying them from Hasport! It can be REAL time consuming.
Wes
Wes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V »</TD></TR><TR><TD CLASS="quote">Here is a page covering the ones I built;
Wes</TD></TR></TABLE>
Well I'm actually expecting most of the post to be for mounts that aren't currently available in the aftermarket. H series into EF chassis may be the most common one on HT.
Maybe we will end up seeing crazier stuff like SR20DET's into Miatas, or something of that nature. I sure hope so.
hey wess nice work
hey wess nice work
We are in the works of making engine mounts and trans crossmembers for SR20DET/ KA24DE into Datsun 280Z.... pics will be up upon completion
I also made a mount on drivers side of my civic to get rid of junk OEM EK drivers side mount... it uses a 94+ teg drivers side mount and i just welded in plates to bolt the mount to. ill post pics of this also....
Cool.
Oh BTW Wes V, on your link it says that you made those mounts to have less vibration that other aftermarket mounts. I have heard that if you put Dynamat on motor mounts, it virtually eliminates vibration.
90civichbsi
26
Mar 26, 2004 05:59 PM
