adjustable upper control arm??
Old Aug 13, 2004 | 08:12 AM
driftt's Avatar
Default adjustable upper control arm??
my 94 accord has a bad upper left control arm and being lowered my camber is also way off and im chewing up tires. so my question is are there any companys that make adjustable upper control arm kits for the accord so i might be able to fix 2 problems at once?
Old Aug 13, 2004 | 08:43 AM
v4lu3s's Avatar
RTFM
never seen one yet
only seen adjustable pivot mounts and adjustbale ball joints for accords.
Old Aug 13, 2004 | 09:19 AM
Confuc1ous's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">never seen one yet
only seen adjustable pivot mounts and adjustbale ball joints for accords.</TD></TR></TABLE>
is it possible to make one?
Old Aug 13, 2004 | 09:48 AM
v4lu3s's Avatar
RTFM
im sure if you work in a machine shop and are creative you could.
Old Aug 13, 2004 | 10:08 AM
Confuc1ous's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">im sure if you work in a machine shop and are creative you could.</TD></TR></TABLE>
i fall under neither of those categories so i guess i wont be having an adjustable control arm anytime in the near future!
Old Aug 13, 2004 | 11:41 AM
.bagged's Avatar
Default Re: (Confuc1ous)
wouldnt spc ajustable ball joints do the trick?
Old Aug 13, 2004 | 02:34 PM
iam7head's Avatar
Default Re: (bagged93accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord &raquo;</TD></TR><TR><TD CLASS="quote">wouldnt spc ajustable ball joints do the trick?</TD></TR></TABLE>
SPC adjustable ball joint would help a little but if the camber is way off, you need a Full adjustable UCA.
OMNI powerusa made those but they do not have one for accord, only civic and teg
Old Aug 13, 2004 | 03:28 PM
16.45_stock_94accord's Avatar
Default Re: (iam7head)
y not get a camber kit... that will atleast fix one problem.. i got my car lowered n im doin the same thing.. i dont feel like buying the kit either lolz..
Old Aug 14, 2004 | 11:29 AM
v4lu3s's Avatar
RTFM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">SPC adjustable ball joint would help a little but if the camber is way off, you need a Full adjustable UCA.
OMNI powerusa made those but they do not have one for accord, only civic and teg </TD></TR></TABLE>
with -3 degrees camber which is pretty damn off i was able to work it out fine with a set of ingalls pivot mount camber kits, though i did not correct much with the clerarance under the fender lining, for as often as most people adjsut their camber adjustable upper control arms really arent much of a need....
area608EG
Jan 6, 2008 04:07 PM
my95civic
Aug 13, 2004 09:44 AM
POS
Nov 27, 2003 01:50 PM
llW0PllNefRex
19
Nov 18, 2003 07:40 AM
92-h23a1
Jun 6, 2003 09:29 PM
