obd1 vs obd0 resistor box for rc 550 p/h injectors
Old Aug 13, 2004 | 04:58 AM
mr. Grind's Avatar
Default obd1 vs obd0 resistor box for rc 550 p/h injectors
i have a b18c1 motor in a 1988crx with p/h 550 RC injectors, obd1 dizzy, obd0-obd1 harness and obd1 ecu BUT i have a obd0 resistor box connected to the 550s. Should i be having problems starting the car and keep it running with the obd0 resistor box?
Will i need an obd1 resistor box?
Thanks
Old Aug 15, 2004 | 12:13 PM
smart monkey's Avatar
Default Re: obd1 vs obd0 resistor box for rc 550 p/h injectors (kingmarc01)
the car should start but it might idle rough or die out due to inj size. you need hondata or something to tune them out. OBD1 saturated injectors don't use a resistor box just peak and holds so you are fine.
Randysi
Apr 4, 2012 10:17 AM
surkitroller
Dec 29, 2009 12:58 PM
racingant
Sep 28, 2005 05:10 PM
mr. Grind
Aug 13, 2004 04:08 PM
kur0ryu
Apr 26, 2004 05:05 PM
