how to get my clifford alarm out of valet mode?
Old Aug 13, 2004 | 12:00 AM
Spence's Avatar
Default how to get my clifford alarm out of valet mode?
my alarm i guess put itself into valet mode how do i get it out?
Old Aug 13, 2004 | 03:10 AM
96BlackHB's Avatar
Default Re: how to get my clifford alarm out of valet mode? (Spence)
depending on what model you have, you have to punch in a code or use your remote. Check your owner's manual.
Old Aug 13, 2004 | 05:49 AM
rjr162's Avatar
Default Re: how to get my clifford alarm out of valet mode? (96BlackHB)
if it's a DEI system, hold the drivers door open and press Button 1, Button 2, Button 1. That should do it (on alarms where the lock/unlock are the same button, that would be button 1 and the 2nd button on the remote is button 2. On ones where lock and unlock are two different buttons, lock would be 1 and unlock would be 2)
Old Aug 13, 2004 | 06:00 AM
foz's Avatar
foz
do you know where your valet switch is?
If it is a single push button switch then it is a DEI Clifford, and you can use the remote, or after turning the key off you can press the valet switch and it will go out of valet...
If it is a two button switch, with a star on one side, and the other side blank then you have an older clifford pre-dei days, in which case you turn the car on and press the star side twice, followed by the blank side.......
Old Aug 13, 2004 | 09:36 AM
Spence's Avatar
well guys i believe its the concept 100 so im not quit sure how to get this taken care of
Old Aug 13, 2004 | 09:04 PM
Spence's Avatar
bump still need to know this
Old Aug 13, 2004 | 10:39 PM
Spence's Avatar
no help????
Old Aug 14, 2004 | 10:35 PM
Spence's Avatar
help?????
Old Aug 15, 2004 | 10:08 PM
TwistedSI's Avatar
Well, depends on if it is a clifford coded valet or a regular toggle. I believe the 100 has a regular toggle.
For starters, are you sure it is in valet mode and does't just have a bad LED lead?
And I'm not positive about the Cliffords but most systems use the toggle to inturupt a ground. When the swith is on and the valet lead is grounded, it puts the alarm in valet mode. In which case you should be able to just flip the switch or just unhook it.
Did it ever work? Is it supposed to have a coded switch and someone installed it with a toggle cause that can cause big problems within the system.
Old Aug 16, 2004 | 06:45 AM
foz's Avatar
foz
pm / email sent with answers...
-- press the headlight and star button on your remote at the same time to take the system in and out of valet-- (according to the owner's manual this is one way)
Old Aug 16, 2004 | 04:57 PM
TwistedSI's Avatar
Default Re: how to get my clifford alarm out of valet mode? (foz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foz &raquo;</TD></TR><TR><TD CLASS="quote">pm / email sent with answers...
-- press the headlight and star button on your remote at the same time to take the system in and out of valet-- (according to the owner's manual this is one way)</TD></TR></TABLE>
I didn't think the 100 had that remote, I thought it was the old grey one with blue buttons.
You can also take the master remote and hit shift, shift, big button.
Old Aug 16, 2004 | 06:32 PM
foz's Avatar
foz
Default Re: how to get my clifford alarm out of valet mode? (TwistedSI)
I grabbed the owner's manual off of DEI's tech site, I think it was the Intelliguard hundred series that had the grey remotes with blue buttons...
Old Aug 16, 2004 | 10:55 PM
Spence's Avatar
thanks for trying to help guys got the stereo place to fix it
michelvaradero
Audio / Security / Video
Nov 3, 2008 05:01 AM
dingusjt
May 18, 2006 09:38 AM
Mysterious
Jan 20, 2006 11:58 AM
athoughts
Apr 5, 2005 11:27 AM
faiz_23
Mar 13, 2002 06:38 AM
