)2 sensor
sohere it is the the O2 sensor wires came apart so it was disconnected droe around and no engine ligght, but as soon as i hooked it up after about 10-15 minutes of driving or less it comes on and runs like ****? i dont know i changed it maybe 5 or so months ago
i have no cat and i have the 1.5 liter intake manifold on a 1.6 the guy b4 did half a swap, also aftermarket headers......any clues?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Juicy05 »</TD></TR><TR><TD CLASS="quote">thanks dick
no need to start calling people names... he said he was just playing... that how you get no help here
i think you need to check the wiring again make sure you have a good connection even bust out the ohm reader and test it out. you may just have a bad o2 as well. if you buy a new one and it doesn't fix the problem you own it...so do that as a last resort.
Edit* after reading your post again you definitally want to check the wires and even replace them... are you sure you put them the right way? how do you know its the o2 that is the problem if you have no engine light?
more info.
more info.
