injector question
Old Aug 12, 2004 | 07:41 PM
jmonee112's Avatar
Default injector question
I searched but I still don't really have a clue what I need injector wise.. I want to get the obd1 h22a injectors for my lsvtec, my car is a 89 crx si so I have that resistor box. Now do these injectors just plug and play or will I need a prelude resistor box and/or take my crx one apart?? Sorry for the noob question, still kinda learning....
Old Aug 13, 2004 | 11:51 AM
jmonee112's Avatar
Default Re: injector question (jmonee112)
bump kinda need some info on this...
Old Aug 13, 2004 | 03:49 PM
devnull's Avatar
You can not use the H22A injectors. Nor should you want to. bigger injecotrs will not give you HP, only give you less mpg. If you really want more fuel get an adjuctable FPR.
Old Aug 13, 2004 | 06:31 PM
b16supertuner's Avatar
Default Re: (qi_doy)
h22 injectors will work, if you use some sort of fuel managment to reduce their duty cycle. such as hondata or uberdata. pay to get your build tuned. they will adjust all that junk for you. I believe you can use any honda resister box, but the prelude one will already have obd1 clips on it, give it a try.
Prudz_lude
Oct 15, 2014 06:44 AM
tyvtec23
Nov 10, 2011 07:11 PM
xXSilentScreamXx
Jul 18, 2007 05:46 AM
GoFastMotorSports
Jan 17, 2005 02:43 PM
Jeff C
Apr 22, 2003 12:37 PM
