REBUILT AND RUNNING PIG RICH
Old Aug 12, 2004 | 07:09 PM
slammedcoupe's Avatar
Default REBUILT AND RUNNING PIG RICH
Engine was taken out of the car(D16Y8) and air conditioning was removed. Bottom end stock crank, eagle rods, SRP pistons ARP head studs. As for the head just a Comp Cam and re-adjusted the valves, and the rest, Skunk 2 Intake manifold, using stock injectors but I have 520cc MSD injectors with stock fuel rail+regulator. Skunk 2 exhaust cat-back AEM CAI, New wires and plugs 2 degrees colder. Anyways the engine was rebuilt and put back in the car. All connections were hooked back up except for 1 air conditioner plug.
ANYWAYS HERE IS THE PROBLEM, When the car is started up it is running PIG RICH, idles like **** and wont rev over 2000. And the check engine light stays solid.
Is the check engine light on cause of the unplugged air conditioner plug or is it something else??Not sure how to check what code its throwing, ot sure how to check (OBDII).
Also am going OBDI chipped with hondata and going turbo
Any help would be greatly appreciated..
slammedcoupe
Aug 14, 2004 04:37 PM
slammedcoupe
Aug 13, 2004 02:38 PM
slammedcoupe
Aug 12, 2004 09:01 PM
slammedcoupe
Aug 9, 2004 07:01 AM
slammedcoupe
Aug 8, 2004 06:34 PM
