how do i check trouble codes
Old Aug 12, 2004 | 06:27 PM
handydandy's Avatar
Default how do i check trouble codes
i just changed the timing belt in a 1992 1.8 liter, and now the thing will not run correctly. i checked the timing, reset the computer, and rechecked the timing. we then did a tune up cause it needed it really bad. is there a way to check what is stored in the computer for trouble codes? it runs at idle like there is nothing wrong, but when you need the power going up a hill at highway speed it actually slows down. any help will be more than what i have now.
Old Aug 12, 2004 | 10:14 PM
IVI's Avatar
IVI
Default Re: how do i check trouble codes (handydandy)
how many miles on the motor?
if you cleared the computer theres going to be nothing stored in there unless you have had a cel after the reset.
how is the compression on the motor?
Old Aug 13, 2004 | 06:06 PM
handydandy's Avatar
Default Re: how do i check trouble codes (IVI)
there are about 135,000 miles on the motor. to reset the computer i disconected the battery for 20 minutes. i never checked the compresion. it was a great running car before i worked on it. the timing belt had never been changed before. mind you the plugs that were in there had a gap of somewhere near 75 thousandths. i was amazed that it was still running.
drchulo4u183
Aug 26, 2010 01:19 PM
Import_spoon
Apr 21, 2008 08:55 PM
nexgen91
16
May 8, 2007 06:39 PM
kicker1_solo
Feb 25, 2005 01:53 PM
leadfoot78
Jan 25, 2003 02:38 PM
