Stock fuel pressure?
Old Aug 12, 2004 | 05:43 PM
LSVtecEK1's Avatar
Default type r fuel pressure????
does anyone know what the fuel pressure is with a stock integra type r regulator?
Old Aug 12, 2004 | 05:47 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: type r fuel pressure???? (LSVtecEK1)
should be between 38-46psi with the hose connected to the fpr.
Old Aug 12, 2004 | 05:51 PM
LSVtecEK1's Avatar
Default Re: type r fuel pressure???? (Gee3)
ok, i thought it was around 40, because my car is running really rich without the aem fpr tuned to only 30 lbs. thanks
Old Aug 12, 2004 | 06:33 PM
[HrZn]4life's Avatar
hose on is about 10 psi higher
Old Aug 12, 2004 | 07:04 PM
SuzukaBlueAP2's Avatar
Default Re: type r fuel pressure???? ([HrZn]4life)
I could be wrong...but doesn't the ITR have fuel pressure around 50 psi?
Old Aug 12, 2004 | 07:32 PM
ZygSpeed's Avatar
Default Re: type r fuel pressure???? (ScreaminTeg)
The book say something like 47-54, with the hose off.
Old Aug 12, 2004 | 08:25 PM
integrasi's Avatar
Default Re: type r fuel pressure???? (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">The book say something like 47-54, with the hose off.</TD></TR></TABLE>
correct
on mine w/ hose out it's @ 54, while hose are on it at 44
Old Aug 12, 2004 | 08:30 PM
5 Lug's Avatar
I just put my AEM fuel rail on with FPR gauge about a month ago and it was set at 40psi with hose connected, and when full throttle was "triggered" under the hood, it jumped to 50psi. Just a few days ago I put the AEM FPR on (store was out of stock at the time I bought my fuel rail) and bumped up the psi to 45 with hose connected (probably about 55 full throttle).
Old Aug 12, 2004 | 08:36 PM
integrasi's Avatar
Default Re: (5 Lug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5 Lug &raquo;</TD></TR><TR><TD CLASS="quote">I just put my AEM fuel rail on with FPR gauge about a month ago and it was set at 40psi with hose connected, and when full throttle was "triggered" under the hood, it jumped to 50psi. Just a few days ago I put the AEM FPR on (store was out of stock at the time I bought my fuel rail) and bumped up the psi to 45 with hose connected (probably about 55 full throttle).</TD></TR></TABLE>
that's pretty weird.......
fuel rail should not change your pressure. might wanna double check your gauge.
Old Aug 13, 2004 | 05:23 AM
5 Lug's Avatar
It didn't. I was just stating that maybe if I changed the Fuel Rail, FPR, and FPR Gauge at the same time and the psi was 40, it could just mean that the FPR was factory set from AEM at 40. But only changing the rail and adding a gauge and having it read 40, would mean that's what the fuel psi is from the dealership because I left the stock FPR on there. (not sure if that made sense or not)
Teamdiesel
Nov 11, 2007 03:43 PM
boostedteg15
Jul 31, 2006 11:40 PM
myballs
Feb 25, 2003 11:18 PM
Kolijian
Jul 4, 2002 09:12 AM
Malice
Mar 26, 2002 08:31 PM
