Honda S2000 Honda S2000
Whats good Compression numbers in each cylinder for you s2k guys?
Old Aug 12, 2004 | 04:51 PM
Soda Popinski's Avatar
Default Whats good Compression numbers in each cylinder for you s2k guys?
Whats the optimum numbers across the board for you guys? Since you guys are at 11:1, im guessing something like 260ish. Right? Or higher? Given the piston rings sealed correctly.
Old Aug 12, 2004 | 11:59 PM
evil vapor's Avatar
Default Re: Whats good Compression numbers in each cylinder for you s2k guys? (Soda Popinski)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soda Popinski &raquo;</TD></TR><TR><TD CLASS="quote">Whats the optimum numbers across the board for you guys? Since you guys are at 11:1, im guessing something like 260ish. Right? Or higher? Given the piston rings sealed correctly. </TD></TR></TABLE>
anywhere from 220+ is deamed normal. Consistancy is key, not how high the numbers are as readings will vary from guage to guage. You'll want to be within a few percent from cylinder to cylinder.
dntnedvtec
Jul 28, 2010 09:41 PM
Dave_Dc2
Nov 3, 2008 10:48 AM
eg6_kaydoo
May 23, 2008 09:10 AM
ginoboy1978
Aug 9, 2005 12:44 PM
opiumdaze
Mar 30, 2005 04:25 PM
