welding flange to cast iron
welding cast sucks, ok here is the deal use nickle wire, with gas (not to sure off hand on the right gas i'll ask today at work)
and the problem with welding on cast is the same reason cast is good for a manifold. it removes of heat very very fast. thus making your weld brittle when you weld on it... a good way to weld on it
1. get a oxy acleyne torch handy
2. heat the cast your going to weld on
3. keep heating the cast as you weld and after you weld to insure it's going to be a some what strong weld.
4. after done welding keep heating the cast for a few moments so the cast does not cool down to fast and become brittle.
Note: welding on cast even done right with a trained welder, still is not very strong but should be fine for a downpipe i would hope.
good luck son.
good luck son.
Someone told me it works best to weld cast, manifolds or turbos, after they have been brought to a couple hundred degrees in an oven, then bring the temp down slow like an annealing proccess in glass blowin.
Search the forum, I think I heard this on here.
Freshdot
Welding / Fabrication
18
Mar 4, 2011 09:30 PM
hootiehoo
Sep 8, 2010 06:15 AM
