How do you change the trun lights in a 2002 civic ex
Old Aug 12, 2004 | 04:32 AM
Duckrc's Avatar
Default How do you change the trun lights in a 2002 civic ex
How do you get the front lights off of a 02 civic ex
Old Aug 12, 2004 | 06:31 AM
AutoXer's Avatar
Default Re: How do you change the trun lights in a 2002 civic ex (Duckrc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duckrc &raquo;</TD></TR><TR><TD CLASS="quote">How do you get the front lights off of a 02 civic ex
You mean you want to change the turn signal lights? If I remember correctly, the turn signal lights are mounted within the fender sheetmetal, so the whole light assy. needs to be removed to change it. Take the bumper off, then there should be 4 bolts that hold the light fixture into place.
Old Aug 12, 2004 | 07:30 AM
Boilermaker1's Avatar
My first guess is READ THE MANUAL, since it does a pretty good job of explaining how to turn the wheel, remove the clip and screw from the fender well, then peeling it back to give you access to the turn signal and parking light harnesses.
Old Aug 12, 2004 | 12:06 PM
AutoXer's Avatar
Default Re: (Boilermaker1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 &raquo;</TD></TR><TR><TD CLASS="quote">My first guess is READ THE MANUAL, since it does a pretty good job of explaining how to turn the wheel, remove the clip and screw from the fender well, then peeling it back to give you access to the turn signal and parking light harnesses.</TD></TR></TABLE>
Yeah, I forgot about that. When I did someones, we were installing some other stuff too, so we had the bumper off already. Make sure you have more pop rivets for the fenderlining though. Everytime I try to take one off, they break because dirt gets trapped in the back of them, and it's a bish to get them out in one peice.
apamc10
Lighting
Sep 16, 2010 09:29 AM
my_gsr_teg
Apr 27, 2008 03:09 PM
Tsoccer63
Honda Civic (2001 - 2005)
Jan 27, 2008 12:00 PM
jrs95civic
12
Dec 26, 2007 07:30 PM
miakae
Jun 24, 2006 11:51 AM
