Stock Integra flywheel weight??
Old Aug 11, 2004 | 11:50 PM
tRex99's Avatar
Default Stock Integra flywheel weight??
How much does the OEM B18a1 flywheel weigh? or out of the S1 tranny?
Old Aug 12, 2004 | 02:30 AM
b20vtecv8killer's Avatar
Default Re: Stock Integra flywheel weight?? (tRex99)
ABOUT 19 LBS
Old Aug 12, 2004 | 04:32 AM
JDubya's Avatar
Default Re: Stock Integra flywheel weight?? (B20VTEC(V8KILLER))
I heard 18. and a type r is about 15.5
Old Aug 12, 2004 | 06:12 PM
tRex99's Avatar
i thought it was heavier or atleast was hoping it was ...ohwell im getting an 8-12 pound not sure yet. im thinking 12 since its more daily driver and im not going to be on the road course everyday or anything. I Just was my car to spin up really fast. Its going to be an 75-8k LS non v-tec...thanks guys take it easy
Old Aug 12, 2004 | 07:09 PM
SuzukaBlueAP2's Avatar
stock flywheel should weigh in an 18lbs.
ITR is 14 or 14.5 lbs.
If you want to go as light at 8lbs, do yourself a favor and spend the extra $$ for a chromoly one. It is strong, lighweight, and they don't get resurfaced.
If you're not going to put much race time in the car, then there isn't a point to it really. That is the purpose of the lightweight flywheel, because on a raod course// auto X you are constantly going up through the revs. A lighter flywheel enables you to down shift heel-toe style and be in the right rpm range faster than the heavy flywheels.
Anyways...good luck with it.
Old Aug 12, 2004 | 09:48 PM
ApexOne's Avatar
it 18.2 lbs. Dont waste 400 dollars on a new flywheel. Go and pull your flywheel and take it to the machineshop. have it lightened and resurfaced. $80 for an 9lbs fly? not bad at all.
Old Aug 12, 2004 | 09:52 PM
gsr-2nr's Avatar
Default Re: Stock Integra flywheel weight?? (ApexOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ApexOne &raquo;</TD></TR><TR><TD CLASS="quote">it 18.2 lbs. Dont waste 400 dollars on a new flywheel. Go and pull your flywheel and take it to the machineshop. have it lightened and resurfaced. $80 for an 9lbs fly? not bad at all.</TD></TR></TABLE>
lightening the stock flywheel is not recommended it screws with driveability. just get a aftermarket its better
Old Aug 12, 2004 | 10:28 PM
Malakai's Avatar
and u have the chance of the shop messing up and the flywheel exploding on u
Old Aug 13, 2004 | 07:00 AM
Default Re: Stock Integra flywheel weight?? (gsr-2nr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr-2nr &raquo;</TD></TR><TR><TD CLASS="quote">
lightening the stock flywheel is not recommended it screws with driveability. just get a aftermarket its better </TD></TR></TABLE>
I was fortunate enough that my OE flywheel didn't shatter on me after having it lightened to 11lbs.
Old Aug 13, 2004 | 08:32 AM
JBBNJ609's Avatar
Default Re: Stock Integra flywheel weight?? (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">
I was fortunate enough that my OE flywheel didn't shatter on me after having it lightened to 11lbs. </TD></TR></TABLE>
ive been driving HARD with a 12 pound ITR flywheel for like 5k miles . .. shatter ??
Old Aug 13, 2004 | 08:41 AM
Default Re: Stock Integra flywheel weight?? (jason bouchard)
Jason...
I'm not trying to scare people away. And you only took 2 lbs off the ITR flywheel versus mine was lighter by 7 lbs. Certainly a big difference.
I had ran my light flywheel for approx. 22k miles, the last few hundred of those miles were turbo'd.
At any rate, If I were doing severe weight reduction in the flywheel area again, I would get an aftermarket chromoly one.
Do-Work
21
Jul 8, 2009 07:06 PM
EJ8 GSR-T
Jan 30, 2006 10:34 AM
iperez
Nov 18, 2004 12:51 PM
Integra_B18B
Feb 23, 2002 04:44 PM
piruries
Jun 24, 2001 09:34 PM
