are 96 b18b blocks the same as 94 b18b blocks,
Old Nov 30, 2001 | 01:04 PM
millertime's Avatar
New User
Default are 96 b18b blocks the same as 94 b18b blocks,
I have a 94 and i know 96s are obd2 but does the obd have ne thing to do with the block, cause I can get a good deal on the block
Old Nov 30, 2001 | 02:28 PM
jdmotorsports's Avatar
Default Re: are 96 b18b blocks the same as 94 b18b blocks, (millertime)
doesnt realy change much on the block its self, just what sensors you have. you might have to have a few holes tapped for knock and oil pressure sensors. but other then that there the same.
Old Nov 30, 2001 | 03:23 PM
Jackson's Avatar
Default Re: are 96 b18b blocks the same as 94 b18b blocks, (jdmotorsports)
ls blocks dont have knock sensors. the only difference is that the obd1 blocks dont hve the ckf sensor on the oil pump. so if you plan on putting an obd1 block in an obd2 car, you will get a code for unplugged ckf sensor.
Old Nov 30, 2001 | 04:18 PM
Default Re: are 96 b18b blocks the same as 94 b18b blocks, (Jackson)
realy..no knock sensor..then why did i have to bore out a hole to install one from my b18a??? i also had to switch the oil preasure and water temp sensors cause on obd-II engines there relocated....hmmmm
StupidSlowRSX
Jul 21, 2008 12:15 PM
wearyfurball
May 8, 2008 08:24 PM
AiL45
Oct 27, 2006 03:28 PM
Si Integra
Sep 30, 2005 09:35 AM
Si Integra
Feb 22, 2004 02:29 PM
