adjusting manual tensioner
well no i guess,
they probablu want you to make sure you can see the timing marks as to get a full rotation
your supposed to losen it and then rotate the engine one ful turn so the line on the cams go all the way around
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by five-0 »</TD></TR><TR><TD CLASS="quote">Ummm... what's so hard about pulling the valve cover anyway?
Dude, you have the massive array of nuts all randomly thrown around the valve cover, and then you have the PCV rubber plumbing dealy! Let's not even get into spark plugs and torque specs.
Adi
</TD></TR></TABLE>Dude, you have the massive array of nuts all randomly thrown around the valve cover, and then you have the PCV rubber plumbing dealy! Let's not even get into spark plugs and torque specs.
Adi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quick99Si »</TD></TR><TR><TD CLASS="quote">
Adi</TD></TR></TABLE>
I guess it is not a task for the lazy. Seriously, massive array of nuts??????? Plugs and specs? Not that bad!
typeR564
Feb 14, 2004 10:45 AM
