same metal type, different grades... how do you choose cover gas/wire?
Old Aug 11, 2004 | 08:48 PM
turbosi03's Avatar
Default same metal type, different grades... how do you choose cover gas/wire?
would different grades of say stainless steel require different cover gas and or feed wire? or is the grade irrelavent?
can anyone share good info on selecting proper gas and wire for any givin application?
Thanks!
Old Aug 11, 2004 | 09:35 PM
Ekasey's Avatar
Default Re: same metal type, different grades... how do you choose cover gas/wire? (turbosi03)
Gas should always be pure argon
ALways use a welding rod that is a grade higher then the material your welding
Examples
304 to 304 = 308
321 to 304 = 308
321 to 321 = 347
Old Aug 12, 2004 | 04:02 AM
Sliced Beard's Avatar
Default Re: same metal type, different grades... how do you choose cover gas/wire? (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">Gas should always be pure argon
Examples
304 to 304 = 308
321 to 304 = 308
321 to 321 = 347</TD></TR></TABLE>
Old Aug 12, 2004 | 05:16 AM
turbosi03's Avatar
Default Re: same metal type, different grades... how do you choose cover gas/wire? (dirtyd463)
cool, but what about the people on other threads talking about mixing argon with c02 for stainless?
strait argon works anyway?
thanks for the good info to help a beginner out
Old Aug 12, 2004 | 05:29 AM
for TIG welding you want to use pure argon and with MIG you can get away with using a 25/75 mix on lower grades of stainless
Old Aug 12, 2004 | 06:02 AM
B18C1CYA's Avatar
but is there any advantage to using just straight argon in your mig? sorry to jack your thread,
Old Aug 16, 2004 | 11:54 PM
L-CON1's Avatar
Default Re: same metal type, different grades... how do you choose cover gas/wire? (B18C1CYA)
no
Old Aug 17, 2004 | 06:19 AM
david@didrace.com's Avatar
Different Stainless Steel filler metals
http://www.lincolnelectric.com...l.asp
Mig Welding Stainless Steel
http://www.lincolnelectric.com...s.asp
millz
Welding / Fabrication
Jan 21, 2013 03:21 PM
MidwestAutoWorks
Dec 3, 2008 06:11 PM
redsikiller
Apr 29, 2006 12:04 PM
lewdude
14
Jan 26, 2005 06:05 PM
true
Jul 30, 2002 08:53 AM
