Mini me and VAFC???
Old Aug 11, 2004 | 08:47 PM
DSSMAX's Avatar
Default Mini me and VAFC???
Hey,
I wanted to hookup a VAFC to my mini me on my A6, but I'm not sure where the wires hookup to the Vtec head......
Does anyone know how to wire up the pressure sensor?
I know which wire is for the solenoid but there are 2 wires comming from the pressure sensor and only one wire comming out of the VAFC......
Thankx,
MAX
Old Aug 12, 2004 | 07:58 AM
DSSMAX's Avatar
Default Re: Mini me and VAFC??? (DSSMAX)
Old Aug 12, 2004 | 08:01 AM
LSVTEC 91 Civic's Avatar
Banned
Not understanding your question, the VAFC is wired to the ECU.. Not the cylinder head. You need an ECU schematic? If so.. what ECU are you using?
Old Aug 12, 2004 | 08:04 AM
USDM 4G VTEC's Avatar
the vafc is all wired to the ecu
the only cable that goes to the head is the VTEC out
the press u refering to, i beleive is more likely the MAP sensor reading
unless u running a VTEC ecu u dont really need to wire the vtec oil press sensor
Old Aug 12, 2004 | 03:45 PM
DSSMAX's Avatar
O.K., I'm useing a D16A6 with a 0DB0 ecu, (no vtec hookups)
I wanted to use the APEXi VAFC II to control the vtec as well as the air/fuel.
There is a wire comming from the VAFC that goes to the vtec oil pressure sensor..
There is only 1 wire but the plug on the D16Y8 head sensor has 2 prongs on it......
Which side does it go in to?
Because there are 2 prongs do I have to wire power to one side?
Thankx,
MAX
solenoid
Old Aug 12, 2004 | 05:18 PM
Fobtions's Avatar
Default Re: (DSSMAX)
disregard the vtec pressure wire from the vafc.
vtec solenoid is one wire. and that should be the only wire goin to the engine bay.
Old Aug 13, 2004 | 08:17 AM
DSSMAX's Avatar
Default Re: (Fobtions)
All right, Thankx....
But does anyone know about the sensor?
Could someone with a Civic EX measure the current comming from the ECU to the oil pressure sensor... I really would like to know...
I think its maybe about 5+ comming from 1 wire.
Thankx,
MAX
civic-one
Oct 4, 2009 01:25 PM
Power Rev Racing
Oct 16, 2005 06:10 PM
ACrite3404
Feb 14, 2005 05:11 PM
FUP23
Sep 17, 2002 04:44 PM
