Custom ECU conversion harness for an........Odyssey?
I just finished building this for a customer. It's for an Odyssey mini-van equipped with an H22a with automatic transmission, P72 auto ecu, and JO2 (prelude) TCM.
It took forever but it was definitely cool making a custom harness for such an original hybrid!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD »</TD></TR><TR><TD CLASS="quote">]hmm, I thought Odyssey's were V6's?</TD></TR></TABLE>
The older ones had 2.3L or 2.2L four cylinders.
sorry to bring this back up, just had a question.
Do you even have to use an AUTO ecu, since the TCM is controlling all the tranny functions?
in my brother's 93 civic, i wired up the tcm from a 94 teg, then used a 5spd P30.
When i has the auto P28 in it, it threw a code 19 (TC lockup sol) since the TCM was performing that function instead.
so that begs the question, is there even a difference between the AT and MT obd1 P74s and P75s? Would the AT one throw a code if installed in an MT car?
also, i'm assuming by looking at the 4 obd2 male plugs above (integrated into one big plug), that the obd2 ecu and tcm are combined into one big case ( i think called the PCM).
I was wondering, because I think this is how my 99 V6 Odyssey is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nuc79 »</TD></TR><TR><TD CLASS="quote">Do you even have to use an AUTO ecu, since the TCM is controlling all the tranny functions?</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nuc79 »</TD></TR><TR><TD CLASS="quote">When i has the auto P28 in it, it threw a code 19 (TC lockup sol) since the TCM was performing that function instead.</TD></TR></TABLE>
P28's aren't meant to work with a TCM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nuc79 »</TD></TR><TR><TD CLASS="quote">so that begs the question, is there even a difference between the AT and MT obd1 P74s and P75s? Would the AT one throw a code if installed in an MT car?</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nuc79 »</TD></TR><TR><TD CLASS="quote">also, i'm assuming by looking at the 4 obd2 male plugs above (integrated into one big plug), that the obd2 ecu and tcm are combined into one big case ( i think called the PCM).
I was wondering, because I think this is how my 99 V6 Odyssey is.</TD></TR></TABLE>
OBD2 cars don't have TCMs. It's all integrated into the ECU.
Yes.
Yes.
Damn. much props. reminds my of RJ DeVera's mom's 99 Odyssey. painfully-bright yellow, formerly V6-now H22-turbo+nitrous. hella swap, and very nice harness.
