A question about intake manifolds
Old Aug 11, 2004 | 07:45 PM
dt4life's Avatar
Default A question about intake manifolds
Hey guys, I know a b16 and type R head can swap intake manifolds but can GSRs and LS's swap intake manifolds?
Old Aug 11, 2004 | 07:53 PM
DA9RsIntegra's Avatar
Default Re: A question about intake manifolds (wannaTypeR)
You want a GSR mani. on an LS? Should work, kinda like the any B-series exhaust manifold to any B-series.
Old Aug 11, 2004 | 08:33 PM
gser67's Avatar
Default Re: A question about intake manifolds (DA9RsIntegra)
not positive but i think the bolt pattern might not match up???? double check that if it does match up, remember the gsr has the secondary intake runners so they probably wont work on the ls
Old Aug 11, 2004 | 08:37 PM
dt4life's Avatar
Default Re: A question about intake manifolds (gser67)
I was seeing about putting my JDM LS 64 mm TB and intake manifold on a GSR. I was shocked when I measured the LS's TB opening and it was 64 mm...just an idea.
Old Aug 11, 2004 | 08:46 PM
boosted k20's Avatar
i highly doubt that u can put a GSR IM on a LS head. the bolt patters dont match up. plus even if it DID fit ur gonna have to modify the throttle cable, but it wont fit.
Just get a SKUNK2 IM or a JG edlebrock manifold and mate it to a BBK throttle body. make sure u port the manifold to fit the BBK TB to get the most outta that combination if u do get these items
Old Aug 11, 2004 | 08:52 PM
Bspec18's Avatar
Default Re: A question about intake manifolds (boosted k20)
GSR IM has its own bolt pattern
Old Aug 11, 2004 | 10:59 PM
dt4life's Avatar
Default Re: A question about intake manifolds (Bspec18)
ok, thanks guys
Double Agent
Jul 25, 2009 02:48 PM
Double Agent
Jul 22, 2009 06:13 AM
wing.jai
May 26, 2009 05:27 PM
89MA70
Jul 7, 2008 07:58 PM
integraballs
Apr 24, 2006 10:38 AM
