How much PSI of boost can a b16/b20 engine handle?
Old Aug 11, 2004 | 06:19 PM
WTBCivicVx's Avatar
Default How much PSI of boost can a b16/b20 engine handle?
Does anyone on the board have a boosted b16/b20? Im curious because my bro has a b16a head and b20 bottom and just wanted to know just incase he plans on boosting it...Thank you
-David
Old Aug 11, 2004 | 06:32 PM
Deep's Avatar
Default Re: How much PSI of boost can a b16/b20 engine handle? (WTBCivicVx)
stay around 8, but tuned right I've seen B18's and H22's take 10-15 and some cats bug out and go higher but they know the risk but are just willing to take it. For yours stay around 8, but stock B20 blocks have pretty weak sleeves so dont push it, they werent built for performance so becareful if its a stock block.
Old Aug 11, 2004 | 06:39 PM
IN VTEC's Avatar
General guidelines are:
MAP sensor - limited to 11psi
head gasket - limits to 15psi
Old Aug 11, 2004 | 06:41 PM
Ri5e's Avatar
Default Re: How much PSI of boost can a b16/b20 engine handle? (IN VTEC)
You should post in the forced induction forum
Old Aug 11, 2004 | 06:46 PM
Xumarius's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">General guidelines are:
head gasket - limits to 15psi</TD></TR></TABLE>
I read that somewhere or something similar to that. hmmmm...
Old Aug 11, 2004 | 06:55 PM
Ajax's Avatar
Default Re: How much PSI of boost can a b16/b20 engine handle? (Xumarius)
So, I know the b20 block isn't made to be a racing block. But if built it couldn't it be better then a b18? Just wondering.
Old Aug 11, 2004 | 07:00 PM
IN VTEC's Avatar
The head gasket is a little more subject to questionability, but the MAP sensor will only tolerate so much manifold pressure before it exceeds the maximum voltage and triggers a fuel cut and CEL code.
Old Aug 12, 2004 | 10:43 AM
WTBCivicVx's Avatar
thank for all the help...i might be boosting it after all...
Old Aug 12, 2004 | 11:55 AM
spoonfed95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WTBCivicVx &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone on the board have a boosted b16/b20? Im curious because my bro has a b16a head and b20 bottom and just wanted to know just incase he plans on boosting it...Thank you
-David</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WTBCivicVx &raquo;</TD></TR><TR><TD CLASS="quote">thank for all the help...i might be boosting it after all...</TD></TR></TABLE>
So who owns this engine? I'd say stay at 8 PSI without some good engine management.
Old Aug 13, 2004 | 07:03 PM
Islandspeed's Avatar
Default Re: How much PSI of boost can a b16/b20 engine handle? (spoonfed95)
I'm boosting 8 PSI and won't be going any higher until I sleeve it and get pistons / rods. My buddy was running a straight B20Z with pistons / rods and went to 11.5 PSI. Bad move... He split all 4 cylinders.
Another guys I know (this is a hard luck story) was doing dyno pulls and his boost controller failed so he spiked 24 PSI and almost lost it off the dyno. Needless to say he split all 4 as well.
If you're going to boost a B20 / B16 VTEC make sure you have a good EMS (I'm using the Hondata S200B) and Boost controller (Apexi AVC-R). As well, stay clear of internal WG on the turbo, they stick. That's something you don't want happening on a B20. Spend the money and get a Tial.
Old Aug 13, 2004 | 07:47 PM
Bowers's Avatar
Default Re: How much PSI of boost can a b16/b20 engine handle? (Islandspeed)
Is the motor already built? or is this something your doing? if it's a b20/vtec (LS/vtec) make sure it's done right, other wise it'll blow up on you. They are a little touchy if not done right and get rev'd to high.
Old Aug 13, 2004 | 08:36 PM
redrex's Avatar
Default Re: How much PSI of boost can a b16/b20 engine handle? (tunergsr32)
try not to go by psi, 7 psi on a small turbo will produce much less horsepower then 7psi on a big turbo. with that in mind there are ppl running 300hp on stock sleeves some r running even more, tunning is important.
Old Aug 13, 2004 | 10:20 PM
SickoneLS's Avatar
7 to 9 depends on comp. ratio too
Old Aug 14, 2004 | 04:34 AM
Default Re: How much PSI of boost can a b16/b20 engine handle? (SickoneLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SickoneLS &raquo;</TD></TR><TR><TD CLASS="quote">7 to 9 depends on comp. ratio too</TD></TR></TABLE>
Absolutly! Stock bottom end on a B20B is 8.6:1. On the B20Z its 9.0:1. Anybody got the math on the difference in boost pressures to yeild the same result?
w.r.t. the max RPM mine cuts at 7500....
Old Aug 14, 2004 | 01:40 PM
URBAN TANK's Avatar
what if you go with a miising link for the map sensor that means u can go higher on the boost right
Old Aug 14, 2004 | 01:54 PM
Cyphear's Avatar
Stock head gaskets are the best head gaskets you can buy, they can handle 30lbs easy. The factory MAP will only read to 11.2psi (.75 bar).
I'd run about 8lbs on that setup, those b20 sleeves are a little thin.
blacc_ej1
Jun 7, 2009 11:35 PM
EBEATS
Jul 28, 2008 02:45 PM
H22a1civic
Nov 12, 2005 03:36 PM
cxhb
May 26, 2005 09:14 PM
TwistedHatch
Apr 21, 2003 11:44 AM
