FOURTH GEAR IS BLINKING HELP!!!!!!!
OK , I JUST DID A MOTOR SWAP AND EVERYTHING IS DONE BUT AFTER I UNHOOKED SHIFT CABLE, MY FOURTH GEAR LIGHT IS BLINKING GREEN, CAR IS AN AUTOMATICC, WHAT IS CAUSING THIS, IS IT POSSIBLE THE SHIFT CABLE NEEDS TO BE ADJUSTED OR SOMETHING, I HAVE NOT DROVE CAR YET, BUT I KNOW ITS NOT STUCK IN FOURTH BECAUSE IT GOES INTO PARK AND NEUTRAL, CAN SOMEONE PLEASE HELP???????
caps are bad! do a search on this and you will how to pull the code from the TCU (transmission control unit)...that will greatly help in narrowing down your problem. not to sound like an ***, but you said you unhooked the shift cable, but did you hook it back up? i assume you did by the post....anyways, find out how to pull the TCU code (plenty of threads....i've never looked into it myself) and go from there. good luck man
ej1 pilot
Apr 9, 2006 06:23 AM
