Is it really worth it to hook up Argon to a mig welder?
Old Aug 11, 2004 | 06:06 PM
Luserkid's Avatar
Default Is it really worth it to hook up Argon to a mig welder?
First off, its about time they made a forum about welding and fabrication. This should be a good forum that i probably well stay at more now.
Now my question is, i have a desent mig welder, Lincoln 100HD welder and i was wondering if its worth it to add Argon to it.
Now i heard Argon cools down the wire faster but is cooling it down really better? Or do i have that wrong and Argon makes it hotter, which would make more sense to me. TIA!
Old Aug 11, 2004 | 06:14 PM
Ekasey's Avatar
Default Re: Is it really worth it to hook up Argon to a mig welder? (Luserkid)
Argon take the place of oxygen, therefore reducing oxizidation
Old Aug 11, 2004 | 06:55 PM
Luserkid's Avatar
Default Re: Is it really worth it to hook up Argon to a mig welder? (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">Argon take the place of oxygen, therefore reducing oxizidation</TD></TR></TABLE>
Sorry but cant you explain that a little better. How does the welds come out with Argon over without? (i never took chem.)
Old Aug 11, 2004 | 06:57 PM
Ekasey's Avatar
I have never welded without argon to be honest. should come out a lot cleaner with less splatter
Old Aug 11, 2004 | 07:21 PM
Dr. EKology's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">I have never welded without argon to be honest. should come out a lot cleaner with less splatter</TD></TR></TABLE>
It will also help prevent the weld from balooning up or putting a hole through your metal.
Old Aug 11, 2004 | 07:44 PM
Wes V's Avatar
Default Re: Is it really worth it to hook up Argon to a mig welder? (EKology)
The simple answer is; YES!!!
I use a mix of argon and co2.
The idea is that the welding occurs in a "bubble" of inert gas (at the welding tip). The welds are a lot cleaner than using flux core wire. (BTDT)
Wes
Old Aug 11, 2004 | 07:50 PM
Luserkid's Avatar
Default Re: Is it really worth it to hook up Argon to a mig welder? (Wes V)
Thanks so far for the answers its helping me understand it a little better. If i wanted to make intercooler pipping and weld them together you guys would recommend using Argon gas for the cleaner look right?
Now my next question is where could i pick up Argon cheap, like maybe a 5 gallon bottle and just refill it if it dies out. Thanks.
Edit: Also can anyone show pics of non argon welds, argon and co2 welds on a mig? Just if you guys can just a butt weld or something quick, thanks.
Doctor CorteZ's Avatar
weld with gas , its the only way to get a decent weld from a MIG.
and it shields the weld from the oxygen , it doesnt take the place of it...
C12 is the gas of choice , FYI.
Old Aug 11, 2004 | 08:14 PM
Wes V's Avatar
Default Re: Is it really worth it to hook up Argon to a mig welder? (Doctor CorteZ)
Luserkid;
You will have to go to a welding supply shop to purchase the Argon or as I use, Argon/co2. You don't "refill" the tank (a less "mis-leading" term than "bottle"), you exchange it when it gets low. The cost isn't that much and I don't think shopping around would do much good.
Ask at the welding shop if they recommend straight Argon or a "mix".
Wes
Old Aug 11, 2004 | 09:26 PM
Ekasey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">weld with gas , its the only way to get a decent weld from a MIG.
C12 is the gas of choice , FYI.</TD></TR></TABLE>
If you really wanna get technical it does take the place of oxygen by displacing it therefore shiedling
Old Aug 11, 2004 | 09:41 PM
4CFED's Avatar
Welding with gas is the way to go.
Metallic inert gas (MIG) welding, done right can come out almost as clean a TIG weld. Flux core welding, (without shielding gas) is less affected by wind, rust or other material containments. Flux core welders are wire fed just like a MIG welder, but <U>can</U> be as sloppy Stick welding. If you are going to weld parts for a vehicle that you may want to show definatly use 75%/25% mixed gas in your MIG. You can buy a bottle and have it refilled at your local welding supply shop, some places allow bottle rentals.
Old Aug 11, 2004 | 09:58 PM
SJcivic's Avatar
Sheilding gas is to shield the weld from airborn contaminants such as oxygen.
Point being: if your not using shelding gas, why are you welding?
Rich
Old Aug 11, 2004 | 10:42 PM
Your choice on gas is also dependant on the metal you will be welding.
Old Aug 12, 2004 | 02:08 AM
adictionbass's Avatar
Im a newbie to welding, just picked it up and ran with out. Only spent about 4 hours on the machine. I use a 75% argon 25% co2 mix.
Old Aug 12, 2004 | 05:08 AM
boosted hybrid's Avatar
Default Re: Is it really worth it to hook up Argon to a mig welder? (adictionbass)
Run argon/c02 mixture when welding metals with Mig that require a higher amount of heat. The mixture allows for a hotter burn.
Old Aug 12, 2004 | 08:23 AM
577HondaPrelude's Avatar
Default Re: Is it really worth it to hook up Argon to a mig welder? (boosted hybrid)
Yes, you want to use the gas. Do a simple test yourself. Weld a bead on some scrap without the gas, then make one with. The difference is night and day.
H23forlife
Jun 26, 2007 09:54 PM
Felliph3
Oct 11, 2006 08:43 PM
dblock91
Nov 19, 2004 03:03 PM
KB96VTEC
Nov 18, 2003 10:59 AM
