someone please check my vacuum lines on my b16
Old Aug 11, 2004 | 05:50 PM
coot_er's Avatar
Default someone please check my vacuum lines on my b16
the b16 is in an Hf and im not sure if its hooked up right
- i know i have the one from TB to map sensor correct
- i have the TWO coming off the manifold T'd together and going in to the BOTTOM of the purge
-i have the one on the top of the charcole canister going into the side of the purge
-the one on the bottom on the charcole canister going to the throttle body
-and there is one other one on the charcole canister that is away from the other two and that is going into the fire wall.
The other things that were in the black box just don't get used?
is this right?
Old Aug 11, 2004 | 05:57 PM
BlueShadow's Avatar
Default Re: someone please check my vacuum lines on my b16 (coot_er)
Sounds to me like you have it hooked up correctly. Check out this diagram for reference, courtesy of droppedcrxsis site.
http://www.geocities.com/droppedcrxsi/vacuum1.htm
Civic Racer X 7
11
Nov 15, 2005 05:22 PM
IVI
Aug 28, 2004 07:07 AM
crx1856
Aug 23, 2003 03:43 PM
B20zvtecek
May 1, 2002 07:45 PM
