water leak behind dash ...going nuts trying to find where its from
when it rains water gets flows behind the dash checked the glass and its ok i even put silicone on the cover that goes on top of the wipers and still.... the only thing that i don't wanna do is take apart the complete dash so if any one can help i would appreciate it...
Check your AC evaporator drain. On my '95 it's way forward in the passenger footwell. Look for a low point in the plastic housing, with a rubber hose going forward thru the firewall. Right where someone can kick it loose...
Sometimes it gets plugged with crud & you have to squeeze it or something to let it drain. You could get under the car & poke something into the end of the tube, but you might get a facefull of old stale water.
What year Integra do you have and under which part of the dash does it come from? 2nd gens are notorious for having water come down by the passenger's feet area.
i had that problem when it rained when i had my 93 ls it turned out it was the heater core... very expensive to fix if you cant do it yourself
the water leak could be from under the dash..
i have a 94 acura i bought and the guy hooked upa system in in and he put it throught a hole in firewall... LOOK at ur gas pedal then lookup and to the rightthere should be a rubber stopper in the firewall, if not thats ur leak!!!
Let me be one of the people to also say F$@% that water leak ive had that on my civic hatch and it was a freakin swimming pool on the drivers side. anyways i checked before and ive had someone pouring water on my car while i looked uder and u can really see where its comin from because it is a little tiny stream of water that flows u can see the water but cant see wheres it comin from. but its got to be either something about the windshield or holes or plugs int he firewall
for the water leak
for the water leak
yhea my car does that **** too i dunno wat it is. I have tried to get it to leak when i wash my car but i have not been able to make it do it. I sprayed the shtiz out of the winshelid but it only does it when i start my car after a long bit of rain. If any one figures it out let me know!!
DeadVet
16
Feb 23, 2005 04:13 PM
