DAMN!!!...183.1 whp and 131.2 wtrq with just bolt-ons!!!
Yeah...made another trip to the dyno yesterday to see what the power steering belt does. My exact mods include:
Spoon Thermostat
Comptech Filter & Icebox
JDM DC 4-1 Header
2.5" CATCO hi-flow cat
2.5" custom piping
2.5" inlet/outlet Dynomax muffler (Pep Boys)
No A/C
Racing Hart 15x6.5 CP-035 (8.5 lbs each)
CEL #67
Baseline run with power steering belt on:
Peak Horsepower = 178.8 whp
Peak Torque = 129.1 wtrq
Run with power steering belt off:
Peak Horsepower = 183.1 whp
Peak Torque = 131.2 wtrq
Not bad for just some bolt-ons, eh? Both runs were done at Dynamic Autosports in Irvine, CA on a dynojet dynamometer and are SAE corrected numbers.
Spoon Thermostat
JDM DC 4-1 Header
2.5" custom piping
No A/C
CEL #67
dam it only gets around 98 degrees here in ga during the summer. I should take off my belts. Who needs ac and powersteering when its hot as *** outside?
. But at least your car would smoke mine.
Unfortunately, I don't have a scanner at home to post them. But I do at work, so I'll try to get them up next week. In summary, the lines look pretty normal compared to most other plots I've seen on the board. There is, however, a 25whp surge when vtec kicks in at about 5700...I think I'll need to get a VAFC to level it out.
Thanks for the props guys...I guess I have truly been blessed with a strong R!
Yeah, considering my stock rims weighed about 15.6 lbs, dropping that weight to about 8.5 lbs per rim probably picked up about 2-3 whp. Every little bit counts!
Where do I look on the dyno sheet to find this SAE correction factor???
DV- who's betting the correction factor is between 1.03 and 1.06
I think the Spoon thermostat is what really did it. You got at least 7hp out of it.
Good Numbers
I have a pretty close setup. So I should be around 185.
Good Numbers
Yeah, I just took the belt off for fun at the dyno. But I feel the marginal gains aren't worth it for street driving, so its back on now. When I get home tonight I'll look on the dyno sheet for the SAE correction factor and let you know.
Just looked at my dyno sheet:
Elevation = 200 ft.
Temperature = 72.9 F
Correction Factor = 1.01
Does that mean the power numbers are better or worse?
Elevation = 200 ft.
FYI I got a correction number of 1.01 on my dyno which was done at ~100ft elevation and 90F. Yours seems a bit high. I would expect a temp that low to yield either a 1.00 or a 0.99.
Type-Rare#1248
Jul 7, 2002 11:32 PM
PYITR821
Jun 17, 2002 07:21 PM
01itr518
Nov 21, 2001 06:35 PM
