Good books or information the web about rollcages?
Just what the title reads. I'm looking for good info on how to fabricate and weld a good rollcage. I've seen a few books at B&N but, nothing that great. Now with this forum I should be able to find someone who knows.
First off you need 2 main tools. One is a pipe bender (about 5k from what i heard) and 2 a good welder.
You need to be able to bend your pipes to the right spots to weld. Its really easy. I was going to make a roll cage until i found out i needed a pipe bender then i said **** it. So instead im welding a B pillar bar to a C pillar bar. Mini roll cage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">First off you need 2 main tools. One is a pipe bender (about 5k from what i heard) and 2 a good welder.
Ack $5k?
Try http://jd2.com
</TD></TR></TABLE>Ack $5k?
Try http://jd2.com
Hmm.... i didnt know they had pipe benders that small, maybe now ill look into getting one myself. But the 5k one i was talking about is the big *** one that exhaust shops use that bends all sorts of pipes then you could also make a pipe wider if you want.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Hmm.... i didnt know they had pipe benders that small, maybe now ill look into getting one myself. But the 5k one i was talking about is the big *** one that exhaust shops use that bends all sorts of pipes then you could also make a pipe wider if you want. </TD></TR></TABLE>
Pneumatic benders = Mega bling
Flinstone's style omish benders = no bling, tons of elbow grease
That's what I figured. I knew the pneumatic pipe benders were $3k+. Looking at the cost of the "cheaper" ones, plus a pipe notcher I'd probably end up buying a Cusco cage for my 240 and just welding it, since it comes bolted.
A buddy of mine got a 24 point WRC spec cage installed in his 2.5 RS. Probably the sickest cage I've ever seen. Even had that X in the back of the car. I swear that car could fly off a cliff and it'd be fine. Guess that's what it's for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bomber »</TD></TR><TR><TD CLASS="quote">Ack $5k?
Try http://jd2.com</TD></TR></TABLE>
Got the exact one in my garage as we speak, accompanied by my Miller 251. Made a ced cage for my brothers silverado and everything is going peachy. Although the *** does leave the tank open... anyways, that JD2 bender works great and is mandrel (mandatory)..
http://www.scca.org download the rulebook and then see what you need to do.
Rich
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuskeR »</TD></TR><TR><TD CLASS="quote">...$3000 unpainted. Not cheap.</TD></TR></TABLE>
For a chromoly TIG'd cage, that is cheap. If your looking for a class winning cage, $7k total shouldn't be unexpected.
Rich
Rich
Rich
would it be worth it to copy an autopower roll bar? maybe copy the dimensions and have a shop bend the tubing, then weld it myself? if not ill just try to find a used one for my DA again..
Don't buy these pice of **** benders
http://www.harborfreight.com/c...32888
I have one and they don't work for **** and crush everything, the dies are horrible...especially the 12 ton one, its bullshit I don't even wanna talk about it
