a/c compressor belt
Old Aug 11, 2004 | 02:38 PM
BlackGS-R's Avatar
Default a/c compressor belt
I need to know if anything is run on the a/c belt besides the compressor? I think my compressor is seized just need to know if I can take the belt off. Thanks for any help
Old Aug 11, 2004 | 02:55 PM
IN VTEC's Avatar
Default Re: a/c compressor belt (BlackGS-R)
If we're talking about an Integra motor, all of the acc.'s are driven separately. Cut away.
Old Aug 11, 2004 | 03:04 PM
BlackGS-R's Avatar
Default Re: a/c compressor belt (IN VTEC)
Yeah it's a 00 gsr is this a common problem? It's only got 40k on it.
Old Aug 11, 2004 | 05:04 PM
chrisnova's Avatar
My 1989 LS has only the compressor connected to it. If it is the same then remove it.
Old Aug 11, 2004 | 05:15 PM
Honda Hick's Avatar
That doesn't sound right with you only having a '99 w/ 40k on it and the compressor is seizing. Why do you think it's seizing? There is also an idler pulley that you use to tighten the A/C belt and that may be going bad. The bearing in that that pulley went on me (at 230,000 miles) and it was only a $15 fix. I really don't think it's your compressor because the Honda's are pretty damn stout. I'm still on my original at 240k and it works great.
BTW, the A/C compressor is on it's own belt but you need to take off the power steering belt to take it off (unless you want to cut it). I really doubt it's your compressor though.
sinister357
Jul 28, 2007 06:36 PM
DBAl
Jul 20, 2006 09:17 AM
BBuncky2
Jan 10, 2006 11:48 AM
92hondalude
Dec 21, 2004 09:47 PM
Acura EL
Oct 4, 2004 03:41 AM
