stock ls pistons in ls/vtec, any clearance problems??
when i do my ls/vtec turbo, i wanna use the stock ls pistons for the time being for the low compression it will create(not sure what the compression will be, does anyone know what it will be)i was just curoius if anyone knew if i would run into any valve clearance problems, and if i can fit oil squirters, will there be any clearance problems with those. thanks
You will not run into clearance problems as long as you do not mill the head, or as long as you run gsr or b16 cams, ITR + cams could equal clearance problems, 9.6.1 compression ratio.
When we took the head off about 8 months later, you could see some nice marks on the pistons from where the valves hit them... not just from the ITR cams, but from overall use. Be careful, there isn't as much clearance as most say there is (unless you have your cam gears set to zero, or something very low).
how about if i had jdm itr pistons in there and had ctr cams... and i might have advanced the timing a bit too much.. would it slap valves??
1995sir
Apr 26, 2006 02:35 PM
jdmefhondachassis
Aug 17, 2004 10:50 AM
Dan GSR
Jan 14, 2004 04:10 AM
