Brake master cylinder
hey i have a problem with my brakes. When i am at a stop the pedal goes all he way to the floor slowly. Im thinking its the master cylinder. So im thinking of just getting one off of ebay from another integra or a type R. What do i actually need to change this out. Is it the part that the fluid goes in and the black piece behind it or what?
Just get a new one. The black piece behind it is the booster. Don't go to the junk yard and buy a new one becuase it may be bad as well and there is no warranty.
also want to know as well. my brakes does the same thing...probably the seal in the master cynlinder is leaking. can i install a bigger one ( say...from a type-r, TL, RL, maybe even a Legend...). anyone know???
http://www.enthusiastsauto.com get a Tokico one.
I wouldn't mess with the factory sizing, a little change could have huge bad effects.
youre better off staying with factory size, less can go wrong with that. make sure you check the one way air valve in the booster...you may have a leak in it. have your booster looked at though, its quite hard to tell if its good or not. check all your lines for leaks as well
mattbatson
Oct 23, 2008 07:30 PM
integra123
Aug 8, 2006 05:52 PM
