92 EG si rack and pinion in a 92 cx??????
Old Aug 11, 2004 | 12:38 AM
jdmhatchy's Avatar
Default 92 EG si rack and pinion in a 92 cx??????
I am close to commiting to put the si rack in my cx, if i take out the power steering will it be close to being the same. I have read on this message board(yes i did search, before someone goes all crazy and tell me to search) that takin out the power steerin makes it a little harder to steer. But other than that,im fine right??? thanxpeople.
Old Aug 11, 2004 | 03:13 AM
mustninty's Avatar
Default Re: 92 EG si rack and pinion in a 92 cx?????? (jdmhatchy)
I would take the power steering out, the difference is minimal. I have a 92 hatch manuel and a coupe with power. I drive the hatch as a commuter (80 miles a day) and if it was hard to turn I would be driving the coupe instead. Plus a little less weight and one less belt for the motor to turn it must add a little bit of power to your ride. I have swapped rack and pinions before its kind of a pain but I have swapped different years (between 92-95 civic\hatch\coupe) and all were a straight swap no mods needed. So I dont see a problem with putting an si rack on your hatch. Good luck
Old Aug 11, 2004 | 02:01 PM
jdmhatchy's Avatar
Default Re: 92 EG si rack and pinion in a 92 cx?????? (mustninty)
thank you dude, good stuff!!!!!!!!!!!!!!!!
Old Dec 18, 2009 | 10:52 AM
strictly_jdm's Avatar
New User
sorry jus to approve so u can put a p/s rack straight into a cx model with no mods?????
turbo_d
21
Mar 26, 2008 09:31 AM
Flite
Dec 5, 2006 06:56 AM
mattjohnston
Sep 16, 2002 09:40 AM
Lookincrazy
Feb 24, 2002 05:12 PM
