Big problem in my Accord 2001 V6
Old Aug 11, 2004 | 12:37 AM
ba55am's Avatar
Default Big problem in my Accord 2001 V6
Hi,
This is my first post, so i wish to have your usual support
My accord V6 2001 automatic gear (50K mile) has some problems which I want to ask about:
First question is in my gearbox, there is a weird sound (make the whole car shake) appears ONLY when the car moved for 20+ min. (it doesn’t appear when I first started the car or when it is still not warm). this sound appear when I shift the gear from the R to the D. is there anyone knows what happened to my car?
Second Question is that the SRS light always appears for me, i sent it to the agency many times and every time they say that they fixed the problem, but unfortunately it appears again. Does anyone know how to fix this problem?
I need your help ASAP
Regards,
Bassam
Old Aug 11, 2004 | 02:11 AM
Mike813's Avatar
Default Re: Big problem in my Accord 2001 V6 (ba55am)
when you shift from R - D are you on a hill or angle?
and with the SRS try looking at a few threads on recalls... theres a link that shows you if you car has been recalled for something if you sign your vin in, and even if you brought it many times... demand they fix it if its under warranty.
Old Aug 11, 2004 | 03:45 AM
ba55am's Avatar
Default Re: Big problem in my Accord 2001 V6 (Mike813)
Ans: No, and i have been told that the gearbox has to be override (sorry, i don't know the correct word) which is a big decision to make.
about the SRS i will search for it.
BAS
Old Aug 12, 2004 | 01:31 AM
av6916's Avatar
If you're not on an incline, hard shifting even from Reverse to Drive might be due to a bad transmission. I suggest you go to Honda and have them check out the transmission. They should do it free since you have an 01 and 01's are under the transmission warranty.
As for the SRS light, try this...
http://www.v6performance.net/f...=2656
JC'S car
Jan 15, 2016 06:46 PM
castleman3183
Oct 24, 2014 11:05 AM
bigdaddyhonda1
Aug 21, 2013 01:14 PM
bmk2001
May 25, 2011 10:58 AM
hatzipri90accord
Apr 1, 2011 12:10 AM
