Adjustable fuel pressure regulators
Old Aug 10, 2004 | 10:38 PM
spreadm's Avatar
Default Adjustable fuel pressure regulators
hey just wondering what psi i should set my regulator to..
n.t DA6 (JDM Honda integra XSi) B16A gen1......done I/H/E...good plugs/ leads/msd coil....
someone told me 35psi but just making sure...at the moment i have a stock fuel system...
cheers
Old Aug 10, 2004 | 10:53 PM
Malakai's Avatar
ive heard 40 is around stock.
Old Aug 11, 2004 | 08:04 AM
SuzukaBlueAP2's Avatar
Default Re: Adjustable fuel pressure regulators (spreadm)
unless you makes the FPR changes and dyno the car before/after, you're not going to know if you made any changes, for the better or worse.
I'm no expert on the B16A, but I would venture to say that even the stock FPR is over 40 psi with the OEM FPR.
without knowing what the factory pressure is, I would say keep it at or above 42 psi.
Old Aug 11, 2004 | 08:20 AM
92integra_gs's Avatar
i believe its 42-50 psi.... you should also get a A/F ratio so you can just look if your running lean or rich...
turboman2.2
Oct 30, 2010 02:38 AM
sc34dc4
Feb 15, 2010 09:33 AM
honda9369
Sep 9, 2004 07:04 PM
976
Jul 21, 2001 01:39 PM
