questions on civic turbo
Old Aug 10, 2004 | 10:16 PM
d15b's Avatar
Default questions on civic turbo
Hello I want to buy a bolt on turbo kit for my 1992 sohc vtec civic do I have to do any modifications to the car for the turbo like pistons and stuff or will it be fine stock.
Cheers
Old Aug 10, 2004 | 10:18 PM
92CivicSiR2's Avatar
Default Re: questions on civic turbo (d15b)
If you want to run higher boost than yes you do because it wont hold up but you can run on low boost on stock internals but may not be reliable or long lived depending on the mileage of the motor
Old Aug 10, 2004 | 10:22 PM
Revolver's Avatar
Default Re: questions on civic turbo (92CivicSiR2)
Depends on amount of boost, condition of motor, setup, the way you drive etc.
Old Aug 10, 2004 | 11:43 PM
Street Ghost's Avatar
Default Re: questions on civic turbo (Revolver)
If you don't smash on it all the time.. it will be okay. Also, it's safer to get it dyno tuned.
Old Aug 11, 2004 | 12:22 AM
RC_SKUBY's Avatar
You should also look into such things as bigger injectors i.e 1g dsm injectors will fit, and a good fuel management system. running around 7psi shouldnt cause harm to a already good running engine.
AfEn808
26
Feb 7, 2023 10:50 AM
themurrell
Apr 7, 2007 05:55 PM
darkirony
Sep 28, 2004 05:55 PM
cliff666
Apr 24, 2004 11:44 AM
NightKids
May 5, 2003 09:41 AM
