anyone fit a starion fmic on a 6gen civic?
Old Aug 10, 2004 | 08:13 PM
lkailburn's Avatar
Default anyone fit a starion fmic on a 6gen civic?
anyone fit one? will it require heavy modification to the bumper cover or support?
looking for someone with personal experience.
thanks for your help
Luke
Old Aug 11, 2004 | 04:37 AM
lkailburn's Avatar
no one?
Old Aug 11, 2004 | 06:05 AM
boost fed ls's Avatar
Default Re: (lkailburn)
I have not done one on a 6th gen but i have done one ona 93 civic hatch, no mods to the bumper support or the bumper cover. I had to mod the intercooler it self bucause of the end tanks. I hope this helps some.
Old Aug 11, 2004 | 06:54 AM
lkailburn's Avatar
hmm. yah it does help a bit. i'm surprised you didn't have to modify anything. it is a rather LARGE fmic. a friend of mine bought a 6" jrc fmic and needed to modify the bumper so it fit. idk.. i found one for really cheap. it may leak but i will build a diy leak tester for it.. test it and if its good or only minor leaks i'll repair the leaks and then see how well i can fit it..
till then anyone else?
did you have to weld shut the stock inlet/outlet ports, cut circles down lower and weld on new pipes? the guy selling the fmic just told me thats what i'd have to do. cuz i asked him why the stock inlet/outlet's were chopped all the way off.
Modified by lkailburn at 4:54 PM 8/11/2004
Old Aug 11, 2004 | 09:49 AM
lkailburn's Avatar
well i went ahead and bought it. he said he's shipping it out today and he's only a state aways so it might be here friday.. maybe not.
i'll keep this thread updated for anyone else considering a starion
Old Aug 11, 2004 | 10:32 AM
Tetronious's Avatar
Default Re: anyone fit a starion fmic on a 6gen civic? (lkailburn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lkailburn &raquo;</TD></TR><TR><TD CLASS="quote">anyone fit one? will it require heavy modification to the bumper cover or support?
Luke</TD></TR></TABLE>
I had to due some trimming on the inside of the bumper cover. The support I didnt really have to mess with to much other than the two holes i drilled to hold the end brackets of the top of the intercooler to the support beam.
Tetronious
00 SI
Boosted
Old Aug 11, 2004 | 11:02 AM
fjt's Avatar
fjt
Default Re: anyone fit a starion fmic on a 6gen civic? (Tetronious)
Old Aug 11, 2004 | 11:26 AM
lkailburn's Avatar
AWESOME!! thank you guys very much
Tetronious: looks like you welded shut the sotck inlet/outlet ports and cut and welded on some of your own?
fjt--looks like you used the stock inlet/outlet tubes? also what bumper modifications did you have to do if any?
Modified by lkailburn at 8:41 PM 8/11/2004
Old Aug 11, 2004 | 12:01 PM
fjt's Avatar
fjt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lkailburn &raquo;</TD></TR><TR><TD CLASS="quote">AWESOME!! thank you guys very much
Modified by lkailburn at 8:41 PM 8/11/2004</TD></TR></TABLE>
It has custom side entanks(but shitty ones)..In that pic i was just test fitting it..it is not actually in the car(actually i sold it and got a bigger one) and i was thinking of putting it like the pic on the red one posted..However if you want to put it like on my pic, you can do it but you will just need more bends for the piping.If i would've wantes to put a straight pipe in there behind the bumper and U bend it into the engine bay i would've had to cut the bumper support ends a lil cause they are in the way..Unless like i said you use xtra bends on the piping to avoid the bumper support end.
Old Aug 11, 2004 | 12:10 PM
lkailburn's Avatar
cool. thanks guys i appreciate the info. it was shipped out today. should be here in a few days.
it has some rock damage so i'm gonna build a diy pressure tester and check to make sure it can hold pressure. and also fix any leaks it has. then i'll start mounting it up to see what needs to get done.
if you have more tips or anything feel free to share. same to everyone else. anything will be helpful i'm sure
Luke
Old Aug 11, 2004 | 12:32 PM
s1ngle's Avatar
the starion IC is a very good size for the price
Old Aug 11, 2004 | 01:35 PM
mEr's Avatar
mEr
Default Re: (s1ngle)
true i got mine for 80 w/ custom end tanks....
Old Aug 11, 2004 | 09:43 PM
Tetronious's Avatar
yup I got a local welder around here to seal off the stock inlet/outlets and port it out from the sides. I think its easier to run it that way and it seems to work more compatible with my turbo kit as well.
Tetronious
00 SI
Boosted
Old Aug 12, 2004 | 04:48 AM
lkailburn's Avatar
^^ very cool man. on the starion i bought... the stock inlet/outlet tubes were cut all the way off.. so i kinda have to do what you did. my dad can do all the welding for me so thats good.. but is there anything special about cutting the ports out on the sides? can i cut say... 2.5" holes and weld on 2.5" pipe? i know the stock inlet/outlet 's were smaller than 2.5"
thanks,
Luke
Old Aug 23, 2004 | 08:09 PM
BlendedEJ8's Avatar
no to thread jack, but i have this similar question but w'a revhard FMIC...anyone
Old Aug 24, 2004 | 03:44 AM
Raunch's Avatar
Default Re: (BlendedEJ)
Why even buy on of this intercoolers when you can get a tyrus IC for i few bucks xtra and it will look wayyyyyyyyy much better.
used Starion IC = $150 or something like that
New Tyrus IC = $200 shipped ( 6" long)
Thats just me tho.
Old Aug 24, 2004 | 04:33 AM
lkailburn's Avatar
^^ i hear what your sayin dude. i wanted the jrc 5".. you can get it on ebay for 155 shipped.
HOWEVER.. i got this starion for 30 shipped hehehe
Old Mar 18, 2005 | 01:54 PM
eK9aT10pSi's Avatar
back from the dead, for the ones that made new endtanks, what piping size did you use and howd you weld it ? im assuming brazing ? TIA
Old Mar 18, 2005 | 02:45 PM
Blanket Jackson's Avatar
I have one on my Eclipse and it was modded to look better. The mounts are fubar'd for my car, so it sits all fucked up like. I like it though. I am willing to sell it if anyone would like to use it on their junkyard turbo setups. I am looking into a Drag Gen 3 intercooler, just cuz they flow good for 9-13 psi.
Old Mar 18, 2005 | 02:54 PM
Speedracer32's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lkailburn &raquo;</TD></TR><TR><TD CLASS="quote">^^ i hear what your sayin dude. i wanted the jrc 5".. you can get it on ebay for 155 shipped.
HOWEVER.. i got this starion for 30 shipped hehehe</TD></TR></TABLE>
haha. i got mine for 30 shipped too. HMT
Old Mar 20, 2005 | 07:49 PM
eK9aT10pSi's Avatar
Default Re: (Speedracer32)
bump for ideas...
GSROWNSU
Jan 7, 2008 05:16 PM
TodaTeg
Jul 5, 2003 09:29 PM
crashtest Sonny
Jul 4, 2003 07:51 PM
Boost2NA
Jan 22, 2003 04:20 PM
Timmayeg
Nov 27, 2002 10:38 AM
