open dpipe issues?
i just recently finished my custom turbo install on my 98 civic ex
i'm running a t3t4
problem is...after taking the car around for the first spin...i realized the turbo is making any boost...
i thought it was an insane boost leak...but i checked everything...everything is on nice and tight
i took the car to a local tuner shop and i was told that my lack of a downpipe currently isn't providing enough backpressure that my lil sohc motor needs to spool a biggie t3t4...
any opinions??
thanx
i'm running a t3t4
any opinions??
thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">Don't ever go back to that shop. </TD></TR></TABLE>
EVER!
what a moron.
you have a boost leak or your turbo is stuck or something...
EVER!
what a moron.
to the left of the turbine blades is there a hole for an internal wastegate?if so cover it up with somehting,like a downpipe flange.all the air is coming out of that hole and you are losing ALL of the pressure to build boost
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol »</TD></TR><TR><TD CLASS="quote">you need more bumper fluid
jk, maybe that is what the shop will tell you next! definitely check your wastegate setup and charge pipes
</TD></TR></TABLE>it's BLINKER FLUID
get it right y0!by the way, open DP ROCKS. so much faster than when i force it through my RSR catback. I need a new 3 inch exhaust me thinks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -TRINiTRON- »</TD></TR><TR><TD CLASS="quote">Open downpipe rules as long as you have a good manifold and wastegate. If not you will see boost creep. </TD></TR></TABLE>
I second that.......sounds a bit loud for me but it's awesome feel.
Name the shop so H-T members don't go there.
WABOM.....
WABOM.....
