open dpipe issues?
Old Aug 10, 2004 | 07:56 PM
taejin11's Avatar
Default open dpipe issues?
i just recently finished my custom turbo install on my 98 civic ex
i'm running a t3t4
problem is...after taking the car around for the first spin...i realized the turbo is making any boost...
i thought it was an insane boost leak...but i checked everything...everything is on nice and tight
i took the car to a local tuner shop and i was told that my lack of a downpipe currently isn't providing enough backpressure that my lil sohc motor needs to spool a biggie t3t4...
any opinions??
thanx
Old Aug 10, 2004 | 08:39 PM
Chris F's Avatar
Default Re: open dpipe issues? (devildicer)
Bull!
-Chris
Old Aug 10, 2004 | 09:02 PM
m R g S r's Avatar
Don't ever go back to that shop.
Old Aug 10, 2004 | 10:18 PM
Sketch_hs's Avatar
Default Re: open dpipe issues? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Don't ever go back to that shop. </TD></TR></TABLE>
EVER!
what a moron.
you have a boost leak or your turbo is stuck or something...
Old Aug 10, 2004 | 10:37 PM
safe driver's Avatar
what's your setup?
this may be a long short.. but maybe the injector grommets aren't sealing?
Old Aug 10, 2004 | 10:57 PM
twkdCD595's Avatar
Default Re:
did you check you charge piping and all the obvious stuff for leaks?
I would never go to that shop for anything... ever.
people think up some stupid **** these days.
Old Aug 11, 2004 | 01:34 AM
eg6T's Avatar
Default Re: Re: (twkdCD595)
to the left of the turbine blades is there a hole for an internal wastegate?if so cover it up with somehting,like a downpipe flange.all the air is coming out of that hole and you are losing ALL of the pressure to build boost
Old Aug 11, 2004 | 05:14 AM
toolowsol's Avatar
Default Re: Re: (eg6T)
you need more bumper fluid
jk, maybe that is what the shop will tell you next! Definatly check your wastegate setup and charge pipes
Old Aug 11, 2004 | 09:13 AM
Sketch_hs's Avatar
Default Re: Re: (toolowsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol &raquo;</TD></TR><TR><TD CLASS="quote">you need more bumper fluid
jk, maybe that is what the shop will tell you next! definitely check your wastegate setup and charge pipes </TD></TR></TABLE>
it's BLINKER FLUID get it right y0!
by the way, open DP ROCKS. so much faster than when i force it through my RSR catback. I need a new 3 inch exhaust me thinks.
Old Aug 11, 2004 | 09:21 AM
-Trinitron-'s Avatar
Open downpipe rules as long as you have a good manifold and wastegate. If not you will see boost creep.
Old Aug 11, 2004 | 10:01 AM
krazn's Avatar
Default Re: (-TRINiTRON-)
so did u find the problem yet?
Old Aug 11, 2004 | 11:41 AM
Ekasey's Avatar
Default Re: (krazn)
On the whole back pressure thing the turbine blades combined with the turbine housing provides backpressure LOL
Old Aug 11, 2004 | 11:48 AM
CRX T-Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -TRINiTRON- &raquo;</TD></TR><TR><TD CLASS="quote">Open downpipe rules as long as you have a good manifold and wastegate. If not you will see boost creep. </TD></TR></TABLE>
I second that.......sounds a bit loud for me but it's awesome feel.
Name the shop so H-T members don't go there.
WABOM.....
projectef
Jul 3, 2007 08:35 PM
1SlowSi
Jun 20, 2005 06:11 AM
Go Fast Civic
Dec 30, 2004 12:28 PM
NVMYSi
Jun 17, 2003 06:43 PM
nd8ch
Apr 11, 2003 12:03 AM
