HELP!!! getting tranny off, stuck at last step....
Old Aug 10, 2004 | 07:51 PM
tallblondkid's Avatar
Default HELP!!! getting tranny off, stuck at last step....
im taking my b16 tranny off tonight (dont ask why) and i got it all off, almost, its spred apart from the block about half inch all the way around.... no matter how much a giggle and pull it wont come off, its like its jammed or somehting... the crank turns, and i tried prying it off with a big wrench ( no pry bar) nothing seems to work... please help me, i know theres alot of smart late nighters out there
Old Aug 10, 2004 | 07:53 PM
BatuKing's Avatar
Default Re: HELP!!! getting tranny off, stuck at last step.... (tallblondkid)
make sure its not hitting the mount.
but I use a jack and support it and then tilt it then raise it then slide it off
Old Aug 10, 2004 | 07:56 PM
Default Re: HELP!!! getting tranny off, stuck at last step.... (BatuKing)
its not hiting the mount... and its on a jack, but should i have the jack as far down as it goes, or up around where the motor is suppose to sit?
Old Aug 10, 2004 | 08:15 PM
BatuKing's Avatar
take the jack and raise the tranny and then move it towards the passenger side fender then go from there
Old Aug 10, 2004 | 08:16 PM
BauleyCivic's Avatar
Risky Business
Are you sure all bolts are off? take the starter out too?!?
Old Aug 10, 2004 | 08:28 PM
wisjdmhonda's Avatar
Default Re: HELP!!! getting tranny off, stuck at last step.... (BauleyCivic)
Did you take off the plate that gaurds the flywheel? That happend to me before.
Old Aug 10, 2004 | 08:29 PM
Default Re: HELP!!! getting tranny off, stuck at last step.... (wisjdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wisjdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">Did you take off the plate that gaurds the flywheel? That happend to me before.</TD></TR></TABLE>
i didnt take that off, am i supposed to
Old Aug 10, 2004 | 10:25 PM
Yeah, take it off cause it connects to your tran and engine.
shortstopNE
Dec 28, 2008 08:01 PM
91_Civic_Hatch
Jun 17, 2007 11:11 AM
tallblondkid
Aug 11, 2004 01:32 AM
tallblondkid
Aug 10, 2004 09:17 PM
Team 4R
Jan 4, 2004 04:03 PM
