400 hp BUILT H22 EG Civic TURBO... "THE CIV" is FOR SALE!!!!!
I am selling my pride and joy! This is a 1992 Honda Civic Hatchback with a CLEAN title! I built this car for road racing, drag racing, and autocross, as well as street driving. It has seen just 3 drag strip appearances, where it ran 12.3 at 110 miles per hour (missed a shift), and 12.4-12.5 at 116-117 miles per hour on STREET tires/PUMP GAS! I have competed in two autocross events and received First place in the very first event in this car!
The engine is a fully built turbocharged H22 (complete specs listed below). Engine has less than 20K on it, and has PERFECT compression. Compression tests show 175-180 psi on all cylinders. New turbo and new Falken Azenis tires have less than 5K miles on them, tires were purchased on April 26, 2004. I have RECEIPTS showing date of purchase for EVERYTHING! Receipts alone, including JUST PARTS EXCEED $22,000! I couldn't believe it myself!
Engine management is run by an AEM EMS standalone ECU and the car gets just over 20 miles per gallon. It drives beautifully through town, stop-and-go traffic and would make a great daily driver! The AEM EMS was tuned by Sean McElderry of TORQUEFREAKS in Portland Oregon for .9 BAR of boost which made this car extremely reliable.
I am also including two additional GRAM LIGHT wheels (Yes, even my drag tires are mounted on Gram Lights, so you get a total of 6 wheels!) with 255/50r16 BF Goodrich drag radials mounted on them, so drag racing is a simple switch of wheels! Also included is 2 additional rear struts with Skunk2 drag launch (900 lb) rear springs and additional coilover perches for height adjustment!
I have all the dyno sheets, time slips, first place trophies, and compression test results, and receipts available to the buyer! I would be more than happy to sit down with the buyer and show him/her anything they need to see before purchasing my baby!
I also have video of the car running at the drag strip and video of the car on the dyno if further proof is needed!
PLEASE email me any questions you have, I would love to answer them. This is the real deal, not like normal cars I see for sale. Several different tuning shops in the Northwest can vouch for how fast, and how CLEAN this car is (I can provide contact information for these shops to the buyer.)
Mods list:
Engine:
BUILT JDM H22a
DARTON SLEEVES
Wiseco 8.8:1 Pistons
Wiseco Piston Rings
Skunk2 nitride coated stainless steel valves
Skunk2 titanium valve spring retainers
Skunk2 valvesprings
ARP Headstuds
Eagle Rods
Micropolished crank
Alien Auto balance shaft eliminators... idles like stock!
Hasport Billet Aluminum motor mounts
Garrett T3/T04E turbocharger custom specs
Tial 46mm Wastegate!
Maxrev THICK wall polished stainless steel turbo manifold
Blitz Dual Drive Blow off valve
POLISHED ALUMINUM Intercooler piping
AEM EMS Tuned by Sean McElderry of TorqueFreaks
3" custom mandrel bent exhaust to an Apexi –1 turbo muffler
Griffin 24x11" air to air intercooler
C&R Radiator
SPAL radiator fan
JDM H22 transmission, less than 4k miles since been FULLY rebuilt by H&A transmission
Quaife LSD
All new gears, shift forks, and carbon fiber synchros
ACT Xtreme clutch
Fidanza Aluminum flywheel
AEM Fuel Rail
AEM Fuel Pressure Regulator
FJO wideband Oxygen sensor with display
Greddy 720cc fuel injectors
GM 3 BAR map sensor
GM Boost Solenoid
MSD SCI Ignition
MSD Blaster 2 coil
MSD Spark Plug Wires
Walbro 255 fuel pump
Earls billet fuel filter
Chassis:
Wilwood Engineering 12.2" brake rotors with 4 piston billet aluminum calipers
Wilwood polymatrix brake pads
Earls stainless steel brake lines
JDM Civic SiR 15/16" Brake Master Cylinder
Rear disk brakes from 2000 Civic SI
Integra Type-R 21mm rear sway bar
Integra GSR rear lower control arms
Tokico Illumina 5 way adjustable struts
Ground Control coilovers with custom spring rates
Rays Engineering Gram Light wheels
NEW Falken Azenis 215/45-16 tires
2 additional Gram Lights with BFG 255/50-16 Comp TA drag radial tires mounted on them
Skunk2 extended wheel studs
Driveshaft shop 400 hp axles
New front wheel bearings
Spare rear struts with 900lb Skunk2 drag launch springs mounted on them!
Interior:
Recaro Speed Seats
Takata Racing harness
Momo Apache steering wheel
Tekniq Autosport quick release steering wheel release
Optional Audio Consol from Honda of Japan w/ FJO display custom installed
JDM Civic SiR gauge cluster
Greddy 52mm Boost Gauge
Greddy 52mm Oil Pressure Gauge
Greddy 52mm Exhaust Gas Temperature Gauge
Razo Carbon Fiber pedals
Momo Shift boot
DC Sports shift ****
Exterior:
NiN Autosports carbon fiber hood
NiN Autosports carbon fiber duckbill spoiler
Vision corner lenses
New front windshield
Overall weight of car with FULL Interior: ONLY 2240 pounds!
During build ALL NEW OEM HONDA gaskets, seals, new timing belt, new water pump, new oil pump were used!
I have received first place autocross trophy in the first event the car entered!
I am asking $14,495 COMPLETE with 2 additional Gram Lights w/ drag radials mounted and spare Skunk2 drag rear suspension
I have over $22,000 in receipts JUST FOR PARTS! Upon purchase I would LOVE to show them all to you! LOL!
This is my baby,... I have put my heart and soul into building this car and I LOVE IT! She must go to a good home.
Here's the link to my ebay post.
http://cgi.ebay.com/ebaymotors...=6256
I wanted to give Honda-Tech-ers the first dibs. I am DEFINITELY NOT leaving the boards, but it is time to part ways with her.
Modified by Hondaddict at 11:33 PM 8/12/2004
Modified by Hondaddict at 9:52 AM 8/13/2004
Mods list:
Engine:
BUILT JDM H22a
DARTON SLEEVES
Wiseco Piston Rings
Skunk2 valvesprings
ARP Headstuds
Eagle Rods
Micropolished crank
C&R Radiator
SPAL radiator fan
Quaife LSD
ACT Xtreme clutch
AEM Fuel Rail
GM 3 BAR map sensor
GM Boost Solenoid
MSD SCI Ignition
MSD Blaster 2 coil
Chassis:
Interior:
Recaro Speed Seats
Momo Shift boot
Exterior:
bump
I personally have taken a ride in this car, this car is absolute HONDA POWER, buy this damn car!!!
**** man, still cant believe it, didnt think it was final till posted on HT
good luck with the sell
for good seller with a badass car
Reid, I wish I could buy this, but as you know onto the s2k and turbo, FYI which should be my ride to Indy Kart
for good seller with a badass carReid, I wish I could buy this, but as you know onto the s2k and turbo, FYI which should be my ride to Indy Kart
****! Its for sale?
For a good car and good tunner. Good luck on the sale. (Just don't tell me your going witha DSM next
inside joke)
Cesar
inside joke)Cesar
where in washington are you located? are you intrested in a trade? 96 ek hatch 5 lug b16a2 greddy 18g turbokit and apexi power fc? let me know. ill get you more info as well as pics
Bump. good luck Reid. To anyone who is interested, I have been around this car ALOT. It's scary fast, It pulls in 4th gear like my h22 hatch pulls in 2nd. It's clean and well taken care of. It has been through very little in it's life, but still drives flawlessly on 4hour road trips. Nearly 400whp(it's not tuned for pure HP numbers BTW), reliable, clean, tasteful, HONDA. what more needs to be said?.........................John
Man awesome car. Just from your desc. of the car made me want to see this bitch. Some might say the price is a lil' high but from the looks and information it's worth it. Good luck with the sell.
Thanks for the bumps guys I really appreciate it. The price is set for the enthusiast that wants the cheapest way to a super-built Honda. Building a honda on your own time, with your own money is WAY, WAY more expensive than buying mine! I spent over $22,000 just in parts, and the majority of those parts were purchased at wholesale prices! That figure doesn't include the original price of the car either, or any of my labor!
I just really want the car to go to a good home. Whoever buys her will appreciate her I am sure of it! I love this car, it's just time for something else for me.
Thanks for looking
Thanks for looking
Yep, I'm selling it! I almost can't believe it myself..... new project is......
SC300 w/ 2jzGTE and a 6-speed. Oh, and college. That is my other new project and reason for selling.
How many of you guys out there are running 13's and better with H22 civic swaps *(Street Trim/Street
NICEHATCH
Sep 27, 2005 05:00 PM
gdrum
Oct 31, 2003 06:56 AM
