Too Lean or too Rich Air fuel ratio on a civic Type R engine?
Old Aug 10, 2004 | 06:59 PM
RedBadge's Avatar
Default Too Lean or too Rich Air fuel ratio on a civic Type R engine?
I Recently did a few runs on the dyno with a 99 civic type R. When we swapped the engine, it immediately went in with a so called mugen ecu/ cai/ 2 1/4 exhaust from the cat back. Anyway the car put down 158hp at 8500 rpm (real rpm) and 109 torque... both to the wheels on a 2 wheel dynojet. Anyways its a a CTR engine so the rev capability is better than that of the ITR, and i assume because of the better bore/stroke+ lower compression/and same built block as the ITR bottom I was wondering if having a air/fuel ratio ranging from 13-13.3 is good at rpms between 7800-8600. The powerband never fell off, not even at 8500, and I thought I was being safe, I shouldve revved to 9000rpm on the afc and see until when the powerband began to drop and really see what MAX whp is. It feels like the powerband begins to fall around 8700rpm (on vafc) when driving... but anyways..... I dont know much about air/fuel ratios...... when it comes to whats too lean to whats too rich for certain setups. The tuners on hand liked the air fuel curve from the runs, they said i guess it was very smooth. But I was with my friend who also just was dyno tuning his protege 5 wagon with a bolt on turbo kit.. and when the air/fuel ratio went above 12 they said it was too lean. Yet these guys were saying that me having 12 -13.3 from 6000 (vtec engagement) to 8500 was ok. I did always think the car ran rich from day one, but it ran great still and the powerband is great with the setup but after seeing the air/fuel from the dyno i was a little concerned.
Anyways I have a vafc2 ( dyno tuner said that me making the mixture richer at the top of the power band I could still gain something extra even though the program on the ecu had a good air fuel curve already) {he never said anything about it being too lean for safety}. I turned up the fuel 2% from 7500 - 9000 rpm. I know it will never be as precise as getting a tuner to actually make changes on a dyno but..... I dont have the money now and im concerned whether I have to worry about being safe with the 13.3 air fuel ratio at about 7000 rpm and above. Would the dyno tuners say it was ok because it was a civic type R block? and maybe they thought it could handle a leaner mixture?
My old engine died on me because of lean conditions and I want to avoid a lean mixture at all costs, so your advice is appreciated
Thanx
Old Aug 10, 2004 | 07:25 PM
mmuller's Avatar
Mad Scientist
Default Re: Too Lean or too Rich Air fuel ratio on a civic Type R engine? (Waterman128)
13.3 is ok, i mean every engine is a little different; but all motor 13.something is good. leaning out a little at the top is good also, you'll have to see.
your tuner was talking about 12 being lean for a turbo car..i dunno. fi hondas are comfortable at 12-12.5.
Old Aug 10, 2004 | 07:30 PM
RedBadge's Avatar
Default Re: Too Lean or too Rich Air fuel ratio on a civic Type R engine? (mmuller)
thanx for the info mmuller? so u recommend getting it back on the dyno and just see what works better?
Old Aug 10, 2004 | 07:36 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Waterman128 &raquo;</TD></TR><TR><TD CLASS="quote">thanx for the info mmuller? so u recommend getting it back on the dyno and just see what works better?
yeah, so you can tune to see what your engine likes better
Old Aug 11, 2004 | 12:32 PM
RedBadge's Avatar
cool
thanx again
Now i know the mixture is safe.
russianswty
Mar 6, 2008 03:28 AM
allmtrdc4
Feb 24, 2006 12:36 PM
Rocket
Jun 16, 2005 09:21 PM
RedBadge
Aug 10, 2004 11:46 PM
ZCHF
Mar 1, 2003 03:20 PM
