Sensor relocation on Skunk 2 Manifold on b16A2 Swap
Old Aug 10, 2004 | 05:27 PM
Emoson's Avatar
Default Sensor relocation on Skunk 2 Manifold on b16A2 Swap
Hey there, I have been working on my civic over the weekend putting a Skunk @2 intake Manifold on and I had some problems with the relocation of the Air Temp Sensor coming off of a b16. The instructions say to relocate to the manifold, but I have never had the sensor, I have a cold air intake, which is where the sensor would be on a stock engine. I went to Honda to pick up the sensor, but it just didn't seem right, so I got ahold of my race shop and they told I need to get it from a type R. I found the part and it looks like it will fit, but I am not sure if it can be integrated into my ECU, I have a plug that should reach, but I don't know if I should have just plugged the hole. If anybody out there has any knowledge about this upgrade, please let me know before I am stuck with a $70 manifold plug. Thanks
Old Aug 10, 2004 | 05:34 PM
pynikal's Avatar
Default Re: Sensor relocation on Skunk 2 Manifold on b16A2 Swap (Emoson)
is it the intake temp sensor? if it is you should have had one on the 3rdd intake runner from the dist. and on the skunk mani if i remeber correctly its on the 4th from the dist. who ever did you swap should have wired that in to it already i'd ask them about that. good luck with that. what did you swap it in as well???
Old Aug 10, 2004 | 05:35 PM
revvin9k's Avatar
A search would help you find your answer.
crist488
11
Jul 15, 2011 09:26 PM
bringmyownend
Dec 16, 2010 08:25 PM
graftuner34
Apr 15, 2008 05:09 PM
str8JDMteggy
Oct 23, 2006 12:57 PM
