codes 3,10,41 and won't rev past about 2500, help!
Old Aug 10, 2004 | 04:31 PM
ICeDoUt's Avatar
Default codes 3,10,41 and won't rev past about 2500, help!
Like the title says. Its an h22 just swapped into a 92 eg. I know what all the codes are, but i don't see why it wouldn't let you rev past 2500....
Old Aug 10, 2004 | 04:38 PM
Andres-eh2's Avatar
mind posting what the codes are and not just the number?
Code 3 is MAP right?
Old Aug 10, 2004 | 04:48 PM
ICeDoUt's Avatar
Default Re: (Andres-eh2)
sorry,
3 is map
10 is intake air temperature
41 is O2
Old Aug 10, 2004 | 06:06 PM
Andres-eh2's Avatar
did you rewire your o2 sensor?
Old Aug 10, 2004 | 06:39 PM
specv5150's Avatar
also wouldnt the ECU be in limp mode if it wont rev past 2500 rpm???
Old Aug 10, 2004 | 08:30 PM
ICeDoUt's Avatar
sent out the harness to hasport to get rewired, and just adapted the wires to the ecu. so i am pretty sure we got the o2 sensor right. Thats one crazy limp mode, when my b16 go in limp mode, it'll still rev up to at least like 7400. But this is an h22 we are talkin about
Old Aug 10, 2004 | 11:09 PM
alleyezonme's Avatar
Default Re: (ICeDoUt)
late night bump!!! the sooner the better, this is my only car!
Old Aug 11, 2004 | 10:40 AM
Default Re: (bumpincivic20)
bump!
Old Aug 11, 2004 | 01:58 PM
specv5150's Avatar
when my ECU was in limp mode, it wouldnt rev past 2500. D16Y5
Old Aug 11, 2004 | 02:11 PM
Default Re: (specv5150)
do you remember what sent it into limp mode?
Old Aug 11, 2004 | 04:09 PM
bump this annoying bitch up so i can drive!
Old Aug 11, 2004 | 05:19 PM
murmur9's Avatar
big bump for you...i know the feeling of having your only car with a NEW engine in it....not work correctly because of something stupid. hope you get it running. I'm also interested to see what it may be.....
Old Aug 11, 2004 | 07:22 PM
Default Re: (murmur9)
thanks buddy!!
Old Aug 11, 2004 | 07:46 PM
Andres-eh2's Avatar
make sure everything is plugged in all the way. also make sure your o2 is good. reset ecu for 15 minutes
Old Aug 12, 2004 | 12:17 PM
ICeDoUt's Avatar
alright we got it figured out, the way hasport had the harness wrapped up, it looked to be that the tps and the map plug were in the right spots. Buttt we had to really stretch and pull to switch them, and thats what it was. As for the other codes, who cares, we are gonna drive it home and work on them to. At least it revs past 2500!!!!!
cpennington89
Feb 20, 2015 05:33 AM
accord2civic2prelude
17
Dec 9, 2009 11:45 PM
goldhatchie89
Aug 28, 2006 12:30 AM
H22aInside
Jul 31, 2003 04:00 PM
reese
Apr 17, 2002 08:33 AM
