low oil level shutoff?
Old Aug 10, 2004 | 03:19 PM
winniepooh's Avatar
Default low oil level shutoff?
Does anyone know if there is a low oil level auto shut off for honda accords?
Old Aug 10, 2004 | 03:20 PM
propwdialogue's Avatar
Default Re: low oil level shutoff? (winniepooh)
i do not believe there is. if you think you might be low on oil, do a simple check of the dipstick and dont start it up...if you dont start the engine, it wont need to be shut off...
Old Aug 10, 2004 | 03:31 PM
edd001's Avatar
no there is not a shut off for low oil that is why if you have a vtec engine it can fail due to low oil.
Old Aug 10, 2004 | 04:32 PM
iam7head's Avatar
Default Re: low oil level shutoff? (edd001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edd001 &raquo;</TD></TR><TR><TD CLASS="quote">no there is not a shut off for low oil that is why if you have a vtec engine it can fail due to low oil.</TD></TR></TABLE>
any engine will seize if you run the motor for with no or low enough oil. dry friction will toast a motor in no time.
Cel will lite for the vtec system malfunction due to low oil.
the car will not shut itself off or prevent to start up for no/low oil.
Old Aug 11, 2004 | 06:19 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by winniepooh &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if there is a low oil level auto shut off for honda accords?</TD></TR></TABLE>Yeah, it's called seizing. Sometimes there's a warning noise, kinda like a grinding screetching sound right before the engine stops.
globy123
12
Oct 18, 2009 03:01 PM
Lil BAiLeY IV
Nov 21, 2005 07:26 PM
Turb00HC
May 22, 2004 06:18 AM
LuckyNuts
Sep 21, 2003 12:49 PM
GruvyTune
Jul 24, 2002 09:58 AM
