need to know where the grond on the alternator goes...
Old Aug 10, 2004 | 11:49 AM
elmalouno's Avatar
Default need to know where the grond on the alternator goes...
the ground wire on the alternator is all corroded so i was going to hook up a wire that is good... but i dunno where that ground wire goes.. it disapears into the main harness
anyone know?
Old Aug 10, 2004 | 12:36 PM
precord96's Avatar
Default Re: need to know where the grond on the alternator goes... (elmalouno)
that single wire on the alternator with a ring terminal is not a ground wire. It goes into the main harness and connects to the positive terminal of the battery.
Old Aug 10, 2004 | 12:42 PM
earthworm's Avatar
Year?
mileage?
All alternators using rubber bushings or washers must use a short ground wire to bridge the insulated area. This,as I recall, is what the '97 uses; but the unit could be grounded directly to the battery or the frame. Then the engine is grounded to the frame and the battery.
Old Aug 10, 2004 | 02:44 PM
elmalouno's Avatar
Default Re: need to know where the grond on the alternator goes... (earthworm)
figured it out thanks guys
Ty Calkins
Aug 8, 2012 10:40 AM
949
Aug 2, 2008 03:59 PM
tcs8ter
Jan 1, 2008 03:22 PM
